Home > Maintenance & Mods (L322) > Park not selecting properly for ign start |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6408 |
Because mine seized up, I "bent" the link rod, which no Park and a new link rod from and fitted by LR .
14th Aug 2019 7:47pm |
alfapat Member Since: 09 Apr 2017 Location: Elgin Posts: 349 |
Recently I lubed the cable are under the box and only did this as park was not in reach of the engagement process , now Park was easily obtained for a limited period and it slots in but only get reverse. So things I can only guess is that perhaps the cable clamp , without looking at it is required to release the forward position.
14th Aug 2019 8:39pm |
Got the beast up on a ramp at the moment , can anyone tell me if the joint at the end of the gear selector cable is meant to swivel with the arm to the gearbox please.
18th Aug 2019 2:19pm |
After trying some adjustments, I can see what’s happened there is a sheath supporting the inner cable when it’s extended into P , so this should be held back by the next clamp back and has slip to hold it in place , well this is broken or rotted away, tried tying it back to support the inner core but it gave way .
18th Aug 2019 4:03pm |
Looking at RAVE, the centre console has to come out. The outer cable is held in place at both ends by sliding washer/clips, and the cable has to be withdrawn "into" the car.
18th Aug 2019 4:50pm |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3973 |
What exactly has broken or rotted away? |
18th Aug 2019 5:05pm |
There is a sheath over the cable that slides ove the the extreme end of the cable , this supports the inner section fro bending when D to P is selected.The sheath has a flanged end which I think is attached to the u clamp and held by the clamp to support the cable . The flange has rotted away , so when Park is selected or any forward motion the inner cable buckles .
18th Aug 2019 8:00pm |
Oh, and RAVE says put the gearbox in PARK before you start. That will be fun if your entire problem is not being able to get into PARK
18th Aug 2019 9:08pm |
Yep , I can select park from below when I straighten the cable and push the selector arm forward , however because this sleeve moves out of place when I do it .
19th Aug 2019 8:41am |
Rather than replace the cable you could consider fitting a wire cable clamp and washers to the cable sleeve either side of the fixing bracket.
19th Aug 2019 9:27am |
Thanks I get the jist of your suggestion, you mean something like a jubilee, although this might be too small for that, maybe cable ties and a washer on the sleeve?
19th Aug 2019 9:48am |
Try EBay item number eBay Item No. 182448759217. |
19th Aug 2019 9:52am |
Ah of course, thanks I’ll give it a go. |
19th Aug 2019 10:15am |
You might need a good few washers to pack out the cable sheath next to the clamps to ensure you are on solid material away from the corroded bit. |
19th Aug 2019 10:31am |
