![]() | Home > Technical (L322) > Help on door latch please |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16315 ![]() ![]() ![]() |
Shouldn’t need programming but would need to be the correct age range ie BMW not FORD ownership era’s 👍 |
Johnsd1v8 Member Since: 06 Jul 2017 Location: Cheshire Posts: 190 ![]() ![]() ![]() |
The only difference i saw was where the cable for the inside door handle clips on to the latch the new one has a small plastic cover that unclips where as my one the whole of the plastic cover comes off right from the electric plug to where the lock barrel goes in |
how can i tell mate as i cant see nor BMW / FORD stamped on either |
The one i bought came from a 4.4 v8 2003 mine is a 54 plate will this matter then |
Check with LR dealer using your VIN is the best bet sir... |
Thanks mate i was just hoping it would be a simple swap but no seems NASA need to help 😂 |
