Home > Technical (L322) > Help on door latch please
Johnsd1v8
United Kingdom 2004 Range Rover Autobiography Td6 Zambezi Silver
Hello there a while back my 54 plate l322 stoped remote locking on the drivers door it would remote lock and unlock all other doors but not the drivers anyhow ive just fitted a latch/actuator from a petrol model not sure if this make a difference but still no remote locking on drivers door noor would it remote lock other doors noor would it lock unlock other doors with the key so for now ive put my old lock back and lock and unlock using the key is there any programmimg needed help is gratefull thanks
Post #524187 8th Aug 2019 8:34pm
Shouldn’t need programming but would need to be the correct age range ie BMW not FORD ownership era’s 👍
Post #524192 8th Aug 2019 8:56pm
Johnsd1v8
The only difference i saw was where the cable for the inside door handle clips on to the latch the new one has a small plastic cover that unclips where as my one the whole of the plastic cover comes off right from the electric plug to where the lock barrel goes in
Post #524194 8th Aug 2019 9:04pm
Johnsd1v8
how can i tell mate as i cant see nor BMW / FORD stamped on either
Post #524195 8th Aug 2019 9:05pm
Johnsd1v8
The one i bought came from a 4.4 v8 2003 mine is a 54 plate will this matter then
Post #524196 8th Aug 2019 9:06pm
Check with LR dealer using your VIN is the best bet sir...
Post #524198 8th Aug 2019 9:08pm
Johnsd1v8
Thanks mate i was just hoping it would be a simple swap but no seems NASA need to help 😂
Post #524199 8th Aug 2019 9:13pm
