Home > Technical (L322) > Play in supercharger |
kezbo1981 Member Since: 20 Jan 2015 Location: Evesham, Worc Posts: 334 |
I have uploaded a video of the play. I'm assuming this isn't normal.
9th Jul 2019 5:57pm |
friskydog Member Since: 16 May 2018 Location: West Midlands Posts: 70 |
I have just been told that the coupler on mine has gone and that it had play where you are showing. I have also been told that I cant just detach the snout/nose to repair. You appear to need to take the whole supercharger off which sounds a big job.
10th Jul 2019 5:56pm |
MattHughes86 Member Since: 01 Jun 2019 Location: Gloucestershire Posts: 140 |
getting the supercharger off it quite simple, does involce a lot of steps but is quite easy, i didnt even need to put the bonnet in the work position to do it.
12th Jul 2019 11:22am |
Yesterday I bought a bearing kit, solid isolator and 10% smaller pulley from Powerhouse-uk's ebay shop. I'm hoping to pull the supercharger off next week and do the work. |
12th Jul 2019 1:46pm |
My pulley play is similar to the one in the video above and it's not normal according to the guy that took my supercharger out in less than 30 mins today. I also need a new throttle housing gasket. I noticed inside the supercharger that the rotors are slightly marked. So a service seems a definite as soon as any sound is heard. My noise was on startup and wasn't regular. So any noise from below the pulley get it checked straight away it's probably the couplar. I will update you when my charger is serviced.
12th Jul 2019 8:33pm |
aaa that looks so familiar...
13th Jul 2019 8:28am |
I am getting mine picked up by Powerhouse UK Chesterfield on Monday so will soon have her back together. Checked the hoses under the supercharger and all seems well thankfully although throttle body gasket needs replacing. Range Rover Vogue SE 2007 L322 4.2 Supercharged 121k. Engine rebuilt @ 120666 Miles |
13th Jul 2019 6:23pm |
Managed to get mine out yesterday.
18th Jul 2019 7:54am |
glad to know im not the only one doing this sort of work.
19th Jul 2019 7:53am |
I'm changing the bearings myself as I have a press. I bought a kit containing the snout bearings, rear roller bearings, oil and a solid coupler from Powerhouse UK and it was around £170. Ive got it all apart now - you need a press to DIY - and the bearings were all fine, just the coupler that was knackered. |
19th Jul 2019 8:26am |
have you got any photos?
19th Jul 2019 8:32am |
Ive been meaning to take some. I watched two really useful videos on youtube which tells you all you need to know about the snout bearings:
19th Jul 2019 8:44am |
So I have my Supercharger back.
14th Aug 2019 7:59pm |
Danwilderspin Member Since: 15 Jun 2016 Location: Cambridgeshire Posts: 2215 |
Hi guys,
14th Nov 2019 2:55pm |
