Home > Technical (L322) > Flip key conversion? |
I never used to rate the tailgate button - however on this rr I have "lock on drive off" which means I'm always going to the boot to find it locked. I s'pose I could just unlock the whole car, but the locks will probably wear out! |
20th Feb 2011 12:47pm |
Nickj Member Since: 13 Aug 2010 Location: Ipswich Posts: 262 |
Just been doing some searching. Im thinking take apart orig key ( just unscerwd mine and all comes out easily). Take out inside bits and put in new key. So need to find a key with same button positioning. Found this;
20th Feb 2011 9:43pm |
Bear in mind that presenting a Vauxhall, BMW or any other key other than ORIGINAL at point of sale will almost certainly end any deal that has been done.....
20th Feb 2011 9:49pm |
Nick,
20th Feb 2011 9:52pm |
It is a BMW key to start with don't forget - circa 1991! But I see where you're coming from. I think if done propperly it will be OK, obviously not glued together etc. It would have to feel nice and solid, as good as original. |
20th Feb 2011 9:55pm |
oh, and any badgeing of orig brand would be removed of course |
20th Feb 2011 9:59pm |
Bought this key which comes with no branding and like shape/style.
26th Feb 2011 7:35pm |
daveo Member Since: 21 Oct 2009 Location: london Posts: 2307 |
i, looks interesting, just bought the bmw diamond key V8 facelift Range Rover Autobiography 22" wheels.
26th Feb 2011 7:57pm |
Looks interesting, let us know how it turns out!
Won't the pre-cut key blade be different? |
26th Feb 2011 11:37pm |
Key blade comes uncut. With the BMW diamond key how will you get over the fact on the RR key 2 buttons are side by side and one above, when on the bmw the 3 buttons are in line? |
27th Feb 2011 3:26pm |
Yes I know that I said "Pre-cut blade" what I meant was that if it is a Vauxhall rather than a Land Rover key fob the dimensions of the uncut metal blade will surely be different. Last edited by Gazellio @ Prestige Cars on 27th Feb 2011 6:26pm. Edited 1 time in total |
27th Feb 2011 6:01pm |
See what you mean Valid point. Will check dimensions when arrives. |
27th Feb 2011 6:20pm |
If its the same width, depth & length I will be amazed...... |
27th Feb 2011 6:27pm |
