![]() | Home > Technical (L322) > Hooray - new car finally! |
Jamiehol Member Since: 26 Sep 2014 Location: Ipswich Posts: 226 ![]() ![]() ![]() |
Yes Bluetooth is standard on a 2007 car, do you see phone not fitted on the head unit if so try and pair with something on your phone and pick Land Rover with the pin 2121.
Danwilderspin Member Since: 15 Jun 2016 Location: Cambridgeshire Posts: 2218 ![]() ![]() ![]() |
Hi there it’s not showing up for pairing anywhere in the center console there is a phone dock - I suppose next check is the unit in the boot then! Cheers Current stable:
Had a quick look on the boot it’s dry as a bone I took a picture of the modules which is bt? Or is it missing? The very top one says Nokia
Gyre8 Member Since: 14 May 2017 Location: Wolverhampton Posts: 259 ![]() ![]() ![]() |
Does your phone find 'Landrover' when pairing from the phone BT menu (not the Console)?
Unnecessary quote removed
Here's a quick pic of my working setup:
Bushy30 Member Since: 03 Jun 2018 Location: Oxfordshire Posts: 1098 ![]() ![]() ![]() |
Looks like the MOST cables are missing from your unit Dan -- the end of the box closest to you! Current: 2011 FFRR Vogue SE 4.4 TDV8
The top box that says Nokia does have a plug missing so I should try finding that first? Any advise on my other points? Cheers Current stable:
Strider Member Since: 08 Jun 2015 Location: Hertfordshire Posts: 504 ![]() ![]() ![]() |
Nice looking car Dan |
Dan see the white fibre's in Gyre8's piccy ^^^ where are yours? -- probably joined together, which probably means the Bluetooth unit is FUBAR and been 'wired out' of the loop Look up bic pen fix on here to see what folk do ![]() Previous: - 2004 FFRR Vogue 4.4 V8 with LPG 1997 P38 4.0 SE with LPG 1997 P38 4.6 Vogue with LPG |
Regarding the disco flashing indicators, you are correct it does need a resistor added to cheat the system.
Thanks guys yes I see what’s missing now |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3247 ![]() ![]() ![]() |
Looks as if the Nokia unit has gone defective and been bypassed. Replacements readily available.
4.2 s/c |
