Home > Technical (L322) > Hooray - new car finally!
Danwilderspin
So some of you may know I have been liking to replace my aging 2002 185k 4.4 v8 for the last couple of months, she still purrs like a kitten and runs nicely but is just getting a bit old and tired, and has started to have an arch bubble along with the mega mileage it has plus the 15-20k I put on per year I thought time for a change.
After wading through a LOT of crap (one with vsr, 5 with unacceptable amount of rot) I found a near rot free example! The back end looks nearly new! I would normally steer clear of a London car but I’m thinking this has never really been off road and it had mud flaps have helped me out here.
It’s does need a few things doing maybe someone could advise,
Firstly the mirror glass is shaking but I can’t appear to clip it in - any ideas?
Secondly the viscous fan is permanently on is there some clutch repair I can do?
Thirdly the nav keep showing a line through gps and thinks I’m in France ?? Any ideas how to fix this?
Fourthly, anyone any idea of the towbar pictured? It’s missing the attachment doesn’t look genuine but prefer the sleekness to the genuine I have and wonder what attachment I need?
Finally, this has had a facelift front end on it and the indicators blink double speed.. guessing a resistor fix? Strangely at night they are fine?
Non issue but a question at 2007 was Bluetooth standard? I can’t for the life of me work out how to enable it?
Cheers!
 Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #517925 9th Jun 2019 10:53pm
Jamiehol
United Kingdom 2007 Range Rover Vogue TDV8 Stornoway Grey
Yes Bluetooth is standard on a 2007 car, do you see phone not fitted on the head unit if so try and pair with something on your phone and pick Land Rover with the pin 2121.
If you can’t see anything to pair with, then check the status of the module in the boot, they do get wet and die.
Post #517928 10th Jun 2019 5:55am
Danwilderspin
Hi there it’s not showing up for pairing anywhere in the center console there is a phone dock - I suppose next check is the unit in the boot then! Cheers Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #517929 10th Jun 2019 6:59am
Danwilderspin
Had a quick look on the boot it’s dry as a bone I took a picture of the modules which is bt? Or is it missing? The very top one says Nokia
Cheers
 Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #517934 10th Jun 2019 8:43am
Gyre8
England 2006 Range Rover Vogue SE 4.4 V8 Tonga Green
Does your phone find 'Landrover' when pairing from the phone BT menu (not the Console)?
I had a line through my Nav GPS icon. Turned out that the roof Shark Fin antenna housing was cracked (weathered) and water ingress had ruined the GPS receiver. You can test if this is the issue by buying a GPS 'puck' (with FAKRA plug) and plugging it directly into the Sat Nav unit in the car's Computer corner.
If that works, either buy new Shark Fin with intact GPS, or mount the puck somewhere it gets a GPS signal.
Post #517935 10th Jun 2019 8:48am
Gyre8
Unnecessary quote removed
Top black unit is Bluetooth unit.
Post #517936 10th Jun 2019 8:50am
Gyre8
Here's a quick pic of my working setup:
From your photos your BT unit seems to be missing the plugged in white double cable?
Post #517937 10th Jun 2019 9:02am
Bushy30
United Kingdom 2011 Range Rover Vogue SE TDV8 Galway Green
Looks like the MOST cables are missing from your unit Dan -- the end of the box closest to you! Current: 2011 FFRR Vogue SE 4.4 TDV8
Previous: -
2004 FFRR Vogue 4.4 V8 with LPG
1997 P38 4.0 SE with LPG
1997 P38 4.6 Vogue with LPG
Post #517938 10th Jun 2019 9:45am
Danwilderspin
The top box that says Nokia does have a plug missing so I should try finding that first? Any advise on my other points? Cheers Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #517949 10th Jun 2019 11:18am
Strider
England 2007 Range Rover Vogue SE 4.2 SC V8 Zermatt Silver
Nice looking car Dan Thumbs Up
Does it have a Nokia docking bay under the centre arm rest?.
Look through the Navigation / TV / Phone booklet (if it came with the car).
I've seen the owners booklet pack advertised on e-Bay if you were not given one with the car.
Happy Days Thumbs Up
Post #517957 10th Jun 2019 12:50pm
Bushy30
Dan see the white fibre's in Gyre8's piccy ^^^ where are yours? -- probably joined together, which probably means the Bluetooth unit is FUBAR and been 'wired out' of the loop
Look up bic pen fix on here to see what folk do Wink Current: 2011 FFRR Vogue SE 4.4 TDV8
Previous: -
Post #517958 10th Jun 2019 1:05pm
Strider
Regarding the disco flashing indicators, you are correct it does need a resistor added to cheat the system.
I guess at night time its ok because the other lights electrical demand masks the low current draw of the indicators.
www.powerfuluk.com/vehicles/range-rover-fu...ades.html. (Look for exterior accessories then lamps and lamp upgrades on the side menu)
Post #517959 10th Jun 2019 1:13pm
Danwilderspin
Thanks guys yes I see what’s missing now Smile will have a look later at this Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #517960 10th Jun 2019 1:42pm
Weegie
Looks as if the Nokia unit has gone defective and been bypassed. Replacements readily available.
What engine? John
GAP iiD BT
Post #517967 10th Jun 2019 3:41pm
Danwilderspin
4.2 s/c Very Happy
With the gps and this not working I am quickly looking at ripping it out and replacing but don’t really want to lose the rear screens which I’m guessing need the from one to work? And can’t see any lvds/rca adapter - a CarPlay interface may be the way to go... Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #517972 10th Jun 2019 4:37pm
