Home > Technical (L322) > Sunroof seal is this normal?
dazza1983
My sunroofs seal has a weird bump at the rear in the middle. Is this normal??
I tried pushing it down but it’s solid.
 Regards
Daz
2011 (61plate) 4.4 tdv8
sumatra black
previous cars
e46 m3
e53 x5
Post #516999 30th May 2019 9:42pm
dazza1983
Anyone lol?
I read somewhere that this seal with the furry / velvet sourround is actually not that important? Regards
Daz
sumatra black
previous cars
e46 m3
e53 x5
Post #517028 31st May 2019 11:31am
jim4244
England 2005 Range Rover Vogue Td6 Zambezi Silver
Mine does not have that bump in the seal.
Jim
Post #517029 31st May 2019 11:34am
dazza1983
HMM , I was afraid of that lol,
weird how its even both sides and right in the middle..
Might sponge some black silicone inside the gap. What are people thoughts?? Regards
Daz
sumatra black
previous cars
e46 m3
e53 x5
Post #517030 31st May 2019 11:39am
Bingo_123
my 10 MY 3.6 TDV8 has the same problem infact.
And i also tried to push it inside cos i thought i could stick it back but its very hard.
i think its age related problem, but lets see if someone has any solution for it.
Post #517055 31st May 2019 3:34pm
Wrecker79
United Kingdom 2017 Range Rover Autobiography 5.0 SC V8 Santorini Black
I once drove my L322 at full suspension height with the sunroof tilted into my car-port.
That resulted in the seal you identify being pulled out of the tapered slot in the sunroof glass by the low first (wood) beam in the roof.
So my suggestion would be not to use a sealant, but to tilt the sunroof and try to refit the rubber/felt seal back into the slot as I did - it was not to hard a job to do, but involved a step-ladder and towels on the roof so I could lean-in and really see what I was doing (and I'm 6'2"!) - at arms length it was not going to play ball and re-seat properly.
W. 2017 - L405 SC - WOW! just WOW!
2014 - L405 4.4
2010 - L322 3.6 - Carried me 100,581 miles then broke big-time
There are 10 types of people in this world;
Those that understand binary,
and those that don't.
Post #517056 31st May 2019 3:35pm
dazza1983
I’ll take a look tonight then.
Should I tutor the sunroof yeah ?
Hopefully it will push back in but I think the metal or whatever is inside the rubber must be bent. It feels really solid when I tried to push it down again with sunroof closed. Regards
Daz
sumatra black
previous cars
e46 m3
e53 x5
Post #517057 31st May 2019 3:53pm
Wrecker79
With the sunroof open, push in-line with the glass (i.e. towards the front of the car)
If I remember correctly, the rubber/glass interface is like a dovetail joint, so there may be a bit of wiggling involved.
Forgive the scrappy picture, but you get the idea.
W 2017 - L405 SC - WOW! just WOW!
2014 - L405 4.4
Post #517058 31st May 2019 3:58pm
dazza1983
Thanks buddy I will take a look.
Looks like I may have to pull it out then squish it down slightly before popping it back in although I have a feeling it is seated in the dovetail correctly. Just lifted on the upper Regards
Daz
sumatra black
previous cars
e46 m3
e53 x5
Post #517059 31st May 2019 4:00pm
dazza1983
Well pulled off and played with the seal. Mine was seated right but at some point some previous owner has damaged it. So for some reason it’s lifted.
I needed up putting a very small amount of black gunge in there just to help with the gap. There is still a gap where the two ends meet at the fury part and I didn’t want to spooge that bit.
Having a look at it I think that it’s not really a water seal as such but more a seal to stop bigger things getting in there. Maybe someone can confirm this??
Hopefully me messing about with it won’t have caused it to leak or anything. Kind of wished I had left it alone lol. Pain in the backside as always.
 Regards
Daz
sumatra black
previous cars
e46 m3
e53 x5
Post #517063 31st May 2019 6:27pm
