Home > Technical (L322) > 4.4tdv8 Air Intake ducting images?
JST
England 2012 Range Rover Westminster 4.4 V8 Stornoway Grey
Does anyone have a link or access to the air intake ducting on a tdv8. specifically there is a pipe joining the passenger side air intake pipe on the vertical section behind the radiator. Pipe joins at 90deg. i am wondering where this comes from or its function? engine breather pipe maybe? Cheers
James
Post #508815 15th Mar 2019 12:13pm
will this help?
http://www.fullfatrr.com/gallery/albums/us...tions..pdf
Post #508818 15th Mar 2019 12:22pm
JST
Thats a great help thank you.
So
the pipe with the red arrow pointing towards it, connects into the air intake on the passenger side (post filter) where does it go to Item 18? turbo inlet valve which is the CSOV? Cheers
James
Post #508819 15th Mar 2019 12:29pm
Baltic Blue
Hope this adds further clarity.
Mike G reg 2.5VM Vogue Portofino red 1991- 1999
Post #508825 15th Mar 2019 1:45pm
JST
that is superb, thank you.
So a leaking turbo seals could send oil up B do we think? i think so. Cheers
James
Post #508830 15th Mar 2019 2:20pm
