Home > General > Ever regretted a purchase?
Andy
I should love the TDV8 we’ve bought but I"m struggling to.
Every day I get this restricted performance fault and it’s getting on my nerves. I find it hard to believe the seller didnt have the same problem. It makes me wonder why he sold it now.
It's running on 22" rims and there is a road noise from one of them, consistent with an out of shape tyre. A kind of " whoop whoop" noise that speeds up as the car goes faster. They are almost brand new wheels and tyres as well.
I bought a newer RR so I would have a bit more piece of mind especially when towing. The TD6 was getting old and I started worrying about its future reliability so I decided to replace it. I thought by buying a newer one I could relax a bit but I’m still on edge.
I looked at a few and settled on this one as it had the lowest mileage and full service history.
I just wish I could sort this fault but it could be anything. On top of this I’m now worried about turbos failing which is common on these I’m told.
Post #507684 6th Mar 2019 8:32pm
JST
England 2012 Range Rover Westminster 4.4 V8 Stornoway Grey
I had exactly the same. Get it to a diagnostic specialist, not a lr specialist. Get it fixed and go from there. Cheers
James
Post #507686 6th Mar 2019 8:35pm
Mr Tee
Window re set : https://www.fullfatrr.com/forum/topic45171...+one+touch
Post #507693 6th Mar 2019 8:53pm
Grofus
Ireland 2007 Range Rover Vogue TDV8 Zermatt Silver
Turbo's failing is not common but not unheard of. To eliminate that potential issue map out the Egr's. They are the main culprit for lunching turbo's on a l322. Turbo failure is more common on the RR sport though.
Get the diagnostic codes read to get to the cause of the restricted performance issue. Don't give up and it will reward you.
Good luck with it 2007 Vogue TDV8 in Zermatt Silver with Charcoal
Post #507700 6th Mar 2019 10:01pm
Defender Dave.
Northern Ireland 2012 Range Rover Vogue 4.4 V8 Java Black
Andy,
I feel your pain. A year ago I bought a 2012 MY 4.4 TDV8 Vogue - one owner, service history and low mileage. Previous to that I have run about 4 Land Cruisers ( among a lot of Defenders, Discoverys, Shoguns,Touregs etc)- the last a 4.2 diesel Amazon. I have had more problems with the Range Rover than all of the Land Cruisers put together - as a matter of fact I cannot recall a problem with any of them. Best advice I can give is get the best warranty you can afford - and stick with it (the RR that is). I have wanted a Range Rover for about 35 years and now ,finally, have one - which I love. My local independent has been great in helping me sort out the problems (BLRC, Saintfield). I actually think some of my problems are self inflicted - I have a timber framing business and frequently tow 3.5 tonnes with a tri axel Ifor Williams trailer - the Range Rover is not as sturdy as the Amazon but it was bought to do a job! So keep the faith - the Range Rover is an incredible vehicle!!
David.
Post #507720 7th Mar 2019 7:34am
dolph34
Ireland 2015 Range Rover Autobiography SDV8 Corris Grey
Have you checked the turbo hoses, common issue with the 3.6. 2015 4.4 AB
GSXR 1000 K5
R1 1998
Post #507723 7th Mar 2019 7:51am
Andy
Yes I took them off and gave them a thorough examination. No splits anywhere.
I think my big fear is the fault being one of several possilities, the worst being a turbo on its way out. Having said that, it pulls like a train and there is no smoke whatsoever. In fact I took a mate out in it who also has a TDV8 and he thinks it's been remapped.
I have the IID BT tool and have posted the fault on another post of mine.
Post #507725 7th Mar 2019 7:59am
Robert
France 2007 Range Rover Vogue 4.4 V8 Zambezi Silver
The whoop whoop could be a wheel baring.
Post #507732 7th Mar 2019 8:36am
Andy
I did think that but the noise seems too far apart to point to a wheel bearing. More in time with the circumference of the wheel if that makes sense.
Post #507735 7th Mar 2019 8:42am
Robert
Last year I replaced 4 tyres with 5 mm on them because my indy told me they where flattened ( same whoop whoop noice). The new ones made the same noice turned out to be the 2 rear wheel barings. Replace the wheel that seem to make the noice with the spare and see if it still makes the noice. (Or better let the garage change them, they are to freaking heavy) Thumbs Up
Post #507738 7th Mar 2019 8:51am
Andy
This sounds like it's coming from the front although it could be the sound travelling along the body of the car.
Post #507739 7th Mar 2019 8:54am
Weegie
Did that include the bottom ones? John
GAP iiD BT
Post #507740 7th Mar 2019 8:59am
Andy
I've only checked the top hoses as I was led to believe they were the main problem. So there are more?
Post #507743 7th Mar 2019 9:21am
Weegie
Yes there are more. eg. https://www.ebay.co.uk/itm/RANGE-ROVER-L32...Sw~y9ZMAXU
As you say, normally the top ones but the others have been known to cause problems. John
GAP iiD BT
Post #507756 7th Mar 2019 11:05am
Jakes
Australia 2019 Range Rover Autobiography SDV8 Santorini Black
Re: Ever regretted a purchase?
Hi Andy, I am the owner of a brand new 2019 RR SDV8 ATB. 8 weeks into ownership I had the "OK to Drive with Caution. Restricted performance". Resulting in just 4 cylinders firing in limp home mode, couldn't get the revs more than 1100 and its now with the Dealership. The report yesterday was that it had a "myriad of fault codes currently being analysed by the Master Tech. They over nighted a part (The MAF Sensor) to start off the process of elimination !! It could also be (they say) the EGR playing up as "it usually does", then again it may be a (not so simple) software update as "these are very complex beasts you know" and the "myriad" (there's that word again) of sensors often become over sensitive ... Lets see ...
So, 8.5 weeks of ownership. Brand New 2019 Model. This is my 5th visit to the dealership.
Week 1 - Critical Battery Warning. Land Rover Assist attended. Nothing that could be done roadside. Took it i. Required a software update.
Week 3 - the self close doors would not self close. Service dept found both front door cards deformed fouling with the sides of the dash. Tow new door cards replace @ (wait for it) their cost of $3500 AUD per card.
Week 3 - The rear tailgate spoiler misaligned. Not picked up in the PDI. Spoiler fouled with gloss black D Pillars. Both D Pillars replaced.
Week 5 - Safety Recall N277 - Indicator lights may not actually light up even though green arrows inside the dash light up. Software Update needed.
Week 8 - Lost power in the middle lane of a motorway at 110 Km/h "Restricted Performance" Red Warning Triangle. Occurs at Random in other driving conditions. Its now in with the Service Department.
$272,930 AUD !! And yet, when it behaves, its a wonderful, luxurious and refined / powerful ride...
Will I keep it ? Should I keep it ? is there any other SUV format that comes close (PS: My Land Cruiser owner friends are having a field day with me at work and on weekends)...
They just get in their beasts and drive off road every weekend while I look at my polished beautiful thing in the garage, take it down to a shopping mall as I am too scared to take into a grass paddock in case it Censored itself and I have to suffer the embarrassment (again) of receiving youtube videos of their "machines"crawling over rocks and Australian outback gullies and the like ... whilst my black beauty is on a tow truck again.
I could've got two and a half new Land Cruisers for my capital outlay....
Thoughts of encouragement ??
It would be remiss of me not to confirm - the dealership have been great. The service department, dealer principal and salesman have all bent over backwards to help. They cannot believe how disappointing a product this has been and off record confirmed that the dealer network have strongly complained to the new MD in the UK about the product malfunctions and bad quality. I understand the Chinese Market has now taken an absolute dive (previously thought primarily due to economic matters like currency exchange rates etc, but now confirmed to be due to product quality issues.
Post #508634 13th Mar 2019 11:12pm
