Home > Technical (L322) > Change access height only with IID BT tool?
Andy
As per title. I can do it on my old non BT on my TD6 but a YouTube video I saw this morning suggests that changing the height affects normal height and access at the same time.
Post #506832 1st Mar 2019 12:21pm
you can on your 2002....you cant on the 2006 onwards as it does all height modes ..
Post #506834 1st Mar 2019 12:23pm
Andy
Well that’s a bit crap isn’t it? Thought the BT tool was all singing all dancing!
Post #506836 1st Mar 2019 12:24pm
Jamiehol
United Kingdom 2007 Range Rover Vogue TDV8 Stornoway Grey
It is not a fault of the tool it is the difference in how the EAS system is designed between the model years
Post #506840 1st Mar 2019 12:30pm
Andy
I guess so. I think I automatically assumed the basics on the car were the same throughout.
Post #506846 1st Mar 2019 12:53pm
Jamiehol
Nope the EAS is very different and so are a few other bits and pieces the 2006 to 2010 ones are really a hybrid interms of systems between the BMW era and the Ford era.
The beauty of the Wabeco EAS is that each height setting has it how specific height in the system where as the later one the heights are basically relative from one master height.
Post #506851 1st Mar 2019 1:13pm
Full Fattie
United Kingdom 2007 Range Rover Vogue SE 4.2 SC V8 Zambezi Silver
I too was disappointed with this. I’d planned on lowering the access height quite a bit to assist with getting the kids and seats in and out. In reality it didn’t really matter much as the front doesn’t go down all that low, even when dropped to bump stops. The back goes very low though.
Post #506855 1st Mar 2019 1:54pm
Robert
France 2007 Range Rover Vogue 4.4 V8 Zambezi Silver
I thought you can set the 3 height modes on the BT by calibrating the normal height (185??) and setting the 3 heights in + steps and minus steps...? Be aware I'm not a tech at all.
Post #506858 1st Mar 2019 2:05pm
Andy
Apparently not. One height setting only
Post #506884 1st Mar 2019 4:19pm
@ Robert
Yes, if you up /down the normal height setting on later cars then it also adjusts the offroad and access heights accordingly .
Post #506890 1st Mar 2019 4:35pm
GraemeS
I produce an add-on kit that uses a rotary switch to select low, off, medium raised or high raised with any height mode which makes it easy to go lower in access height. However its costly just for occasional use but if the need is pressing enough then maybe worthwhile. PM me for details if interested.
Post #506920 1st Mar 2019 7:47pm
