Home > Maintenance & Mods (L322) > EGR Cleaning ??? |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4302 |
Are there any EGR fault codes? You'd only know if you've had the car plugged into a diagnostics.
22nd Jan 2019 9:23am |
cozzy Member Since: 15 Jan 2019 Location: Norfolk Posts: 76 |
Hi Dr Rob, thank you for your speedy reply ! I havn't as yet scanned the car.......I will be purchasing a scan tool shortly to see. With regard to the flush on the gearbox, I have just ordered a new zf filter and zf oil for the 8 speeder. I'm going to change the filter and replace the trans fluid that escapes / lost , then drive in for a month and drop the oil out and top up as required. I realise I will never get it all out (as a flush will) though believe several of these oil changes periodically will help the trans no end.
22nd Jan 2019 9:39am |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3770 |
Welcome to the forum.
22nd Jan 2019 9:51am |
Hi Mike , thank you for your reply . Ive not looked at the Wiki posts........I will take a look cheers .
22nd Jan 2019 9:54am |
