Home > Technical (L322) > Heater not blowing hot unless on max |
AKIS Member Since: 23 Apr 2009 Location: GREECE Posts: 186 |
Hi there i am facing almost the same problem.Difference is that i donot have warm air at any stage.Hot only when at max temp and from 27 and below only cold.
29th Mar 2017 3:33pm |
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1374 |
I don't know about the 'hot on max' aspect, but I would check the final stage resistor. Only Range Rovers since 1988 |
29th Mar 2017 4:49pm |
JoeRRV8 Member Since: 03 Feb 2017 Location: Yorkshire Posts: 9 |
Ok thanks, let me know how you get on with the face plate swap. Not sure about the FSR , I thought this controlled fan speed? |
30th Mar 2017 9:09am |
When my 2004 4.4 ceased to heat I had the FSR changed and it worked again, beyond that my technical knowledge is inadequate I'm afraid. Only Range Rovers since 1988 |
30th Mar 2017 10:53am |
Has anyone else had this problem and managed to solve it? I’ve changed the valve on the passenger side wing and made no difference, also the final stage resistor. The heater works as it should for a couple of miles after cold start up then it just goes colder unless you put the temperature setting on max then it’s like being in an oven. I thought it could be air locked but if it was surely it wouldn’t work at all. The weather is cold at the min and this is really bugging me , on the plus side when summer comes around the air con works a treat. |
20th Jan 2019 9:30pm |
p38arover Member Since: 16 Dec 2015 Location: Western Sydney Posts: 1526 |
I've had a no heat problem for three years. Last week I found out I didn't have a heater problem, I had a user error problem.
20th Jan 2019 9:54pm |
Coming home I thought I try something. I turned off the air-conditioning and got an improvement in heating.
21st Jan 2019 8:57am |
Hmmm.
I don't know if there is any real monitoring of the auxiliary cooling pump but T4 did show the pump as being off and shortly after, as the engine warmed up, it indicated the pump was on. However, this may only indicate power is applied to the pump. Ron B. VK2OTC 2003 L322 V8 Auto 2007 Yamaha XJR1300 Previous: 1983, 1986 RRC; 1995, 1996 P38A; 1995 Disco1; 1984 V8 County 110; Series IIA |
22nd Jan 2019 12:42am |
It was cold (23 deg C/73 F) and wet today so I thought I'd try the heating again..
2nd Feb 2019 8:15am |
ohuntsman Member Since: 21 Mar 2016 Location: Surrey Posts: 337 |
Have you both done the thermostat?
3rd Feb 2019 3:16am |
Gsxr1250dave Member Since: 20 Oct 2018 Location: London Posts: 890 |
My heater works as it should until the engine is up to full running temp. I changed both the circulation pump and heater valves just to be sure....unlike others its my drivers side that is permanantly hot hot hot. Passenger side adjusts as it should. Drivers side burning hot. |
3rd Feb 2019 8:12am |
Yes, mine has had the thermostat mod done. Ron B. VK2OTC 2003 L322 V8 Auto 2007 Yamaha XJR1300 Previous: 1983, 1986 RRC; 1995, 1996 P38A; 1995 Disco1; 1984 V8 County 110; Series IIA |
3rd Feb 2019 11:21am |
Was the 1st thing i did when i bought it. Im going to check the lpg vapouriser hoses have been connected up to the correct pipes when its a bit warmer and get the aircon regassed. |
3rd Feb 2019 5:06pm |
No mines not had the mod done, the heater did start working normally again the other day for a trip to Lincolnshire and back from Leeds then went out for a short trip yesterday and normal service had resumed |
4th Feb 2019 9:03pm |
