Home > Maintenance & Mods (L322) > Front Wipers not stopping at rest position
muddycharles
United States 2008 Range Rover HSE 4.4 V8 Bonatti Grey
Hi there,
I have a question for the RR braintrust. My 2008 HSE is having wiper problems - the wipers tend to go past the rest position (back up) about 2 inches about 7/10 times.
I have two questions
1) Can I do anything about it? ( switch electrics, mechanical issue)
2) If not - can I replace the wiper motor without taking apart the whole wiper system (powerful UK has a video that stops at replacing the motor but its a good hour long job to get there.
Thanks! 2008 HSE B. Grey
Overfinched
NavTV retrofit
Post #492429 15th Oct 2018 5:01pm
Flyingfocrs
Scotland 2014 Range Rover Autobiography SDV8 Santorini Black
Just a thought but the mk1 Focus used to have a similar issue and the fault was with the wiper relay.
Not sure if l322 is the same but try swapping the front and rear wiper relays over.
Post #492436 15th Oct 2018 6:03pm
mjdronfield
I had similar, but worse. Had to change wiper motor. Can do it without changing all the linkages......but......you can only buy the motor with the linkage. 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #492447 15th Oct 2018 6:51pm
mjdronfield
http://www.fullfatrr.com/forum/topic37388.html?highlight=wipers 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #492448 15th Oct 2018 6:53pm
