Home > Technical (L322) > How long for suspension to rise back to normal? |
Andy Member Since: 23 Feb 2009 Location: Shropshire Posts: 2938 |
My EAS seems sluggish. When driving off from access mode, the light flashes as it should. I timed it the other night and it took 1 min 44sec to go back to the normal setting whilst driving along. I've read somewhere it should be back to normal ride height within 50 yards, but I managed to drive the end of the street (nearly 1/2 mile) before it was back to normal. It takes 8 seconds to lower. It all seems to work fine apart from that - motorway setting, off road etc. 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded |
13th Apr 2009 11:14am |
Larry Member Since: 03 Dec 2008 Location: East Midlands Posts: 262 |
Shouldn't be that long. Yours does sound very sluggish. Do you get the message on the dash display saying its raising slowly? If I sit there and raise and lower the suspension a couple of times I get that message, presumably because I've used all the air in the reservoir and it's not had enough time to replenish.
13th Apr 2009 12:08pm |
delsilencio Member Since: 08 Apr 2009 Location: toulouse Posts: 116 |
Owners manual says: ......until 180sec. XJC, RRV8, Series1 86 and 107% of real pleasure |
13th Apr 2009 3:00pm |
There should be enough air in the reservoir tank to do at least 1 raise from access to standard, but in practice I have found it takes an age to get from standard to extended. I think part of this may be wait comands - the suspension should adjust under heavy braking/accellerating/cornering so sometimes I think this may be whi its not going anywhere.
13th Apr 2009 4:30pm |
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6369 |
It does sound like its sluggish and there may be a simple issue. Odd that the EAS is derived from the original system trialled on the Classic and then on the P38, so why it still has problems who knows..
14th Apr 2009 8:02am |
Sorry, I was using layman’s terms, because when you say off road mode people get confused! When I was reading through the description and operation section in the workshop manual I actually found no mention of the “Extended Mode” that was implemented in the Classic and P38 System. To say that the L322 EAS operation is in any way based on the Classic/P38 system is stretching it… The system was completely re engineered from the beginning (which is why although lessons were learnt from the earlier systems, a whole host of new problems were introduced). The EAS ECU on the L322 is far superior, with a greater range of Plausibility Scenarios and a better ability to work around system failures using substitute values and complex mathematics to work things out. Anyway, back to Extended Mode – I think it was ditched because of the Crosslink Valves, you couldn’t have both systems. If you can find info on Extended Mode then I would be very happy, I was shocked that the L322 doesn’t have it. Dan |
14th Apr 2009 9:49am |
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3745 |
I read in my handbook that the "super" extended mode could be activated by keeping your foot on the brake and moving the button again over to the high postion, but no matter how many times I have tried, I still can't seem to get the sequence right...
14th Apr 2009 10:06am |
I tried mucking about with the modes one day , and just kept the knob in the raise position for a good few seconds after and the " Extended Mode " kicked in and lifted it even higher ............ ====================================
14th Apr 2009 10:10am |
OMG - the excitement is too much! I'm guna go try this at lunch time!! |
14th Apr 2009 10:12am |
yes thats what I tried to do, right lunch time I'm giving it a go too shall we be real enthusiasts and time them - best of 3 access to extended. Winner gets a new bic to shave their beard |
14th Apr 2009 10:57am |
From Access, from Standard or Off Road?
14th Apr 2009 11:11am |
a real enthusiast would do a lap time from access to standard, to extended to super extended, average it all out over 3 and correct to 4 decimal places, post the results and also have a poll to see who's was the fasted...
14th Apr 2009 11:15am |
I got all excited then and clicked the link - I might have to register that domain! |
14th Apr 2009 11:17am |
As it's a sunny day, don't forget to take off your Corduroy jackets with leather elbow patches! Discovery 4 HSE
14th Apr 2009 11:45am |
