Home > Maintenance & Mods (L322) > 7 pin to 13 pin tow electrics conversion
Andy
Has anyone fitted a 13 pin tow plug to their FF?
I’ve just removed the two 7 pin plugs and have attempted to fit a 13 pin. However on pin 9 there is meant to be an orange wire (permanent live I think) but I can’t see any orange wires in the loom.
I’ve got as far as pin 8 (pink) and I have 4 wires left.
White/red
Yellow/brown
White
White with lettering on it.
So that’s only 12 wires for a 13 pin plug.
Can anyone help?
Post #491429 8th Oct 2018 3:03pm
Bushy30
United Kingdom 2011 Range Rover Vogue SE TDV8 Galway Green
It looks like the 12N maps exactly to the same numbers of the 13 pin, only when you get to the 12N do things start to get a bit iffy!
Does this help: -
http://wellread.me/12n-12s-wiring-diagram....de-12n-12s Current: 2011 FFRR Vogue SE 4.4 TDV8
Previous: -
2004 FFRR Vogue 4.4 V8 with LPG
1997 P38 4.0 SE with LPG
1997 P38 4.6 Vogue with LPG
Post #491430 8th Oct 2018 3:27pm
Bushy30
Actually here's the cross map: -
https://caravanchronicles.files.wordpress....k-list.jpg Current: 2011 FFRR Vogue SE 4.4 TDV8
Previous: -
Post #491431 8th Oct 2018 3:31pm
Andy
That’s the same wiring diagram I’ve been working to except for pins 9 to 13 are different colours to what’s in my loom
Post #491432 8th Oct 2018 3:34pm
Bushy30
Pin 4 from 12S (Green) to Pin 9/13 (should be orange) Current: 2011 FFRR Vogue SE 4.4 TDV8
Previous: -
Post #491433 8th Oct 2018 3:40pm
Bushy30
The only thing I'd be worried about is the gauge of the wires you have from your loom -- a lot of the wires you're dealing with from now on in should be a thicker gauge! Current: 2011 FFRR Vogue SE 4.4 TDV8
Previous: -
Post #491434 8th Oct 2018 3:42pm
Andy
I’ve only got the one green wire and I’ve fitted that to pin 4 on the 13 pin plug as per the diagram above.
Post #491435 8th Oct 2018 3:43pm
Andy
This is what’s left.
Post #491436 8th Oct 2018 3:46pm
SandySix
United Kingdom 2007 Range Rover Vogue TDV8 Stornoway Grey
I take it you have removed the previous 7 pin sockets without a note of what was connected to each pin?
If not it should just be a matter of matching pin to pin whatever the wire colour is..
Post #491437 8th Oct 2018 3:52pm
Bushy30
Yes, sorry I see the dilemma now, sorry assumed you knew the original pin locations Sad Current: 2011 FFRR Vogue SE 4.4 TDV8
Previous: -
Post #491439 8th Oct 2018 4:01pm
for the tin tent there is nothing which needs a perm feed from the car afaik. Fridge and charger will be 12v switched. so if that is all you have....... There is nothing that can't be fixed with a hammer😜😜
Post #491440 8th Oct 2018 4:02pm
Bushy30
4 is all that is required, beyond the pink already done -- but that's me assuming they map colour for colour -- which I'm not sure they do -- I was working pin to pin if you see what I mean!
The four you have left should be +ve, plus it's earth, and switched +ve plus it's earth!
Guessing I'd go with the whites being earth................ Current: 2011 FFRR Vogue SE 4.4 TDV8
Previous: -
Post #491441 8th Oct 2018 4:06pm
Andy
It’s a two year old Swift with the LED tail lights. Not all cars work with them and mine is one of them. The LED indicators flash rapidly and in answer to this, Swift retrofit a module to the caravan. However there are several different types of module depending on what kind of car you have. They couldn’t test my FF as there was no live present which I’m told is pin 9 (orange).
And no I didnt make a note of the old plug as I didn’t realise it would be cross referenced to the new one in terms of pin numbers . Learn something every day!
Post #491442 8th Oct 2018 4:10pm
AJGalaxy2012
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Bonatti Grey
Try this, my electrics had been on fire!
http://www.fullfatrr.com/forum/topic48429.html
j BMW i3 Electric Car
2012 Full Fat RR 4.4 TDV8 (now gone)
2006 VW Touareg 3.0 TDi V6
Post #491443 8th Oct 2018 4:12pm
Andy
Makes sense. I’ll test them and see.
I seem to recall on a previous project, the yellow and brown being permanent live.
Post #491444 8th Oct 2018 4:13pm
