![]() | Home > Technical (L322) > Torque Converter Problem - Mechanical or Electrical? |
Grofus Member Since: 24 Mar 2017 Location: Co Clare Posts: 577 ![]() ![]() ![]() |
RRPhil is the man you want. Sounds electrical to me though. When was the box last serviced? 2007 Vogue TDV8 in Zermatt Silver with Charcoal |
stuart_2006 Member Since: 17 Jul 2018 Location: Holsworthy, Devon Posts: 126 ![]() ![]() ![]() |
I haven't got any paperwork to suggest that the gearbox has ever been serviced - so it's quite possible all original, and I'm aware that 120K miles may be pushing it. Just trying to get an idea if this particular problem is electrical or mechanical. |
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1426 ![]() ![]() |
When in low range, there is no sport mode i dont think, its just manual selection of gears ... which is what you seem to be getting. When in high range, the sport mode is available, with the addition of specifying manual selection of gears ... again what you're seeing from the car.
Hi/lo switch doesn't work (sorry, should have added that in the original post!) Not an issue in itself as I'm never likely to need lo range ... |
Highroller Member Since: 18 Jul 2016 Location: Hampshire Posts: 565 ![]() ![]() ![]() |
If the switch is in op, Is this causing the erratic display I wonder?.
I'm with the above - if your hi/lo switch is faulty then it makes some sense you are seeing odd readings. Land Rover Addict
Well, given that there is a problem with the switch, and that what you describe tallies with the type of behaviors the switch affects ...
Just an update - thanks to all who have replied. Another forum member who lives fairly close to me helped me look at and clear the fault codes with his IIDtool. The Hi/Lo switch was completely unresponsive. On clearing the fault codes the Hi/Lo switch would work and we could switch into Lo range and back to Hi range (so the transfer box motor works) but the 4x4 screen and instrument pack messages/lights didn't seem to agree with the box position. Looking at the live values on the IIDtool, it said the box was in Lo range when clearly it was in Hi. A quick drive round the block has brought back the transfer box fault codes 0x5221, 0x5223, 0x52F1, and the Hi/Lo switch does nothing again. Next step is to replace the ECU (which is cheap) and check the wiring between the ECU and the box motor connector, then look at replacing the box motor. |
Final update. Took out the battery to get to the transfer box ECU and wiring. Measured resistance between potentiometer wiring signal and ground (or reference voltage - can't remember which) which was OK. But measuring between potentiometer reference voltage and potentiometer ground was open circuit - should be around 5K ohms. Checked wiring between ECU and transfer box motor connector and all OK. So off with transfer box motor and check potentiometer.
