Home > Technical (L322) > Rear ventilation button |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35286 |
default seems to be 'on' whether you switch it off or not..
1st Oct 2018 8:19pm |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7796 |
It sort of bugs me too. I can count on one hand the number of times peeps have travelled in the back of my car, so I’d like to know what it’s doing...is it just heat? If I have AC on full cold I assume rear will blow same, irrespective of button? 2011 Range Rover Vogue SE 4.4 TDV8
1st Oct 2018 8:31pm |
dolph34 Member Since: 14 Sep 2015 Location: Kildare Posts: 1724 |
It does bug me but when my 2007 was the other way i hoped there was an easy fix , something like holding it in for 5 seconds or the like.
1st Oct 2018 8:46pm |
John w Member Since: 14 Jan 2018 Location: Cranleigh, Surrey Posts: 439 |
I found on mine (2011 spec, 4 zone a/c) that if I set the fan speed from the rear seat control to minimum, it doesn't come on.
2nd Oct 2018 11:53am |
Which one on here? It’s either for auto fan or auto air distribution on knob 7, or auto/always on/always off air recirculation on button 1.....I would imagine.
2nd Oct 2018 12:22pm |
Hi , if the diagram is for me , its not on that picture, the switch is under button 1 on the diagram/ picture. 2015 4.4 AB
2nd Oct 2018 4:17pm |
this,
2nd Oct 2018 4:39pm |
Thats it Stan 2015 4.4 AB
2nd Oct 2018 4:42pm |
Sorry, it was for John W.
2nd Oct 2018 4:43pm |
Stan beat me....again. 2011 Range Rover Vogue SE 4.4 TDV8
2nd Oct 2018 4:44pm |
2nd Oct 2018 4:49pm |
Woofster Member Since: 12 Jul 2018 Location: Toronto Posts: 121 |
According to the manual, it is called the rear control isolation switch.
2nd Oct 2018 6:25pm |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8512 |
Fart diverted button.
2nd Oct 2018 6:49pm |
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1374 |
Agreed it is a bore to have to switch it off every time. I'm not aware of it being possible to programme it otherwise. I got used to it. Only Range Rovers since 1988 |
2nd Oct 2018 8:12pm |
