![]() | Home > Maintenance & Mods (L322) > Sat Nav Software and Map Upgrades |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35511 ![]() ![]() |
you can download freely from here. http://rapidshare.com/files/387720328/Land_Rover_Navi_DVD.txt ... - .- -.
AMD Member Since: 16 Jul 2010 Location: The South Posts: 811 ![]() ![]() |
Thanks Scary.
nav on the move is expensive..i tend to put all my destinations in at the beginning then when on the move i pick recent destinations...the beauty of the built nav which is very good btw, is an aftermarket nav has to be fixed up at the start and taken down when you reach where your going, not to bad at the beginning but this will annoy you after a while.. ... - .- -.
bozmandb9 Member Since: 06 Dec 2010 Location: Wallingford, Oxfordshire Posts: 1028 ![]() ![]() |
Sorry to be dense, but what do you mean by nav on the move? 2012 SDV8 Vogue SE |
The later models - 2005+ do not allow you to enter an address whilst on the move - although I thought this was a "market restriction"? Could be wrong though as I dont know much about the newer ones... Your 2002 Bozman is fine though, mk3 and mk4 did not have this limitation. ![]() |
sportin Member Since: 12 Mar 2011 Location: USA Posts: 26 ![]() ![]() ![]() |
Follow this link...it explains how to make it work on the fly...works like a charm on my06 HSE...if you shut the car off, you would have to do the procedure again to make it work..
whilst on a journey yesterday i used the 753 code and tbh i cant see the excitement about watching tv on the move ..i found the picture and sound fading in and out and the cost of getting this feature working really isnt worth it.. ... - .- -.
HUGI Member Since: 23 Oct 2010 Location: Jona-Rapperswil Posts: 244 ![]() ![]() ![]() |
if you have access to an IDS system (diagnostic stuff) you can do it by yourself. There is a how to for the dealers on LR's topix system. |
RRVSE Member Since: 18 Apr 2009 Location: Bury Posts: 597 ![]() ![]() ![]() |
753 can allow front passenger to watch a dvd film aswell though , but the only time I have found it useful is when sat in traffic and I am stop starting a lot and don't want to keep putting the car out of gear and the handbrake on just to see the TV for a few seconds (as the other annoying thing is that when you do use the normal method, the screen is always shrunk back on the left hand side of the screen again and you have to tap it to resize it to full screen each time you stop - dumb!). Steve Main car : FFRR L405 Vogue SDV8 Other car : Vauxhall Lotus Carlton Past cars : FFRR L322 Vogue TD6 SE (Sept 2006 MY07) ; LandCruiser SWB ; 4-Runner ; Supras; XJS V12 LeMans |
luckily i've not been in a traffic jam since having the range , but i can see the entertainment value in doing the 753 in a jam.... ... - .- -.
