Home > Technical (L322) > Rave - connectors listing
MrP
England 2011 Range Rover Autobiography 5.0 SC V8 Santorini Black
I was hoping to get some info from RAVE on the position and pinout of some connectors but the ones I need dont appear in the connectors section of the electrical lib but are detailed on the circuit diagrams? For example the Mic connector C1303 is there with picture and wiring diag - the next connector in its path C2044->C1669->C2136 (the voice control box end) do not appear in the library.
Is there a newer version of RAVE or am I just looking in the wrong place?
I know what wires to look for thanks to the circuit diags but was expecting the connectors and pinouts to be detailed in the same way as all the others seem to be...... "On first name terms with my local Dealer......now."
'61 Plate 5.0SC Autobiography - in Black ——— Gone
'53 plate 4.4V8 Vogue Bonatti Grey inside and out. ----- Gone
Post #48913 5th Feb 2011 7:08am
d00d
2008 Range Rover Supercharged 4.2 SC V8 Stornoway Grey
Connector map
I know this is an ancient post I'm replying to, but I've got the same problem. Big Cry
My P38 RAVE had a lovely chapter where every connector was listed with description of the location, even pictures for some!
Now I'm trying to trace a line in my L322 and the electrical diagram gives not the slightest hint as to where the faffing things are located! Banging Head
Anyone have an addendum for the workshop manual showing this? Bow down 2008 SC L322
2001 P38, Epsom Green, fully restored SOLD
Post #525187 18th Aug 2019 12:50am
p38arover
Australia
What are you looking for? Ron B. VK2OTC
2003 L322 V8 Auto
2007 Yamaha XJR1300
Post #525237 18th Aug 2019 11:40am
RAVE for the L322 (02-06) has the same connectors listing, all of which are referred on the wiring diagrams .
Post #525243 18th Aug 2019 11:56am
d00d
Aha!
Seems like the electrical diagram PDF linked in the wiki (and many other places around the intarwebs) simply doesn't include the connector info. Confused
So I got a one-day subscription for only my specific vehicle on TOPIX for a whole $16 and downloaded everything I thought I could ever need using a combination of CurlWget (wget mode only as curl doesn't recurse) and a little editing of the default wget syntax output to add these options:
 -r --level=10 --page-requisites -k --content-disposition -c --adjust-extension -p --convert-links
HTH! Cool
P.S. small hint, don't use the default starting page for any of the downloads or you'll get lots of extra junk. If you're not into reading HTML you should use FireFox to break the left-hand iframe out into a separate window and then use that page as the "source" for the CurlWget syntax generator. Wink
P.P.S. expect several hours even with a fast connection. I only got the main stuff, (workshop manual, electrics and few other bits and bobs), and it was still >425MB total! Rolling with laughter 2008 SC L322
Post #525327 19th Aug 2019 3:28am
