Home > Maintenance & Mods (L405) > At What Mileage Should Axle, Gearbox Oils etc be Changed on
MJGH
United Kingdom 2017 Range Rover Autobiography SDV8 Aintree Green
Hello
First time posting on here but have been lurking in the back ground reading posts for quite a while.
Cant seem to get any definite answers as to what should be changed at what service interval.
Even engine oil is a bit vague, is it every 12 x months, 16k miles or as the car dictates regardless of mileage or time scale?
Thanks in advance for any pointers.
Post #483932 20th Jul 2018 7:15pm
bembo449
United Kingdom 2002 Range Rover Vogue Td6 Adriatic Blue
on the FF I think gearbox oil is 60k but it will do no harm at all to do it at 50k or even 40k , modern engine oils ar so capable of handling the miles these days , every 10k is a bit excessive but non the less , more often is better , every 12 month is ridiculous if the car is only doing 5k a year say
Post #483933 20th Jul 2018 7:17pm
michael. it would be helpful to know what model/engine you have so can you fill in your car profile .. ... - .- -.
Post #483934 20th Jul 2018 7:26pm
I don't think there is a service interval as such - apart from engine oil.
Gearbox on the L405 (at least the SDV8) is technically sealed for life.
I did all the fluids at 60k Thumbs Up
Post #483937 20th Jul 2018 7:52pm
MJGH
Apologies for any discourtesy.
2017 MY 4.4 SD V8 AB
Post #483941 20th Jul 2018 8:36pm
I do mine every 40K sir Thumbs Up
Post #483950 20th Jul 2018 10:55pm
MJGH
In answer to my own question.
It would appear if you go to Land Rover online service history, click register, input your vin no, select servicing information and then service type.
You will get a list that you can print off of everything that should be carried out at each service.
For my car
engine oil 16k / 12 months
brake fluid at 48k / 36 months
transfer box & locking differential oil at 80k / 60 months
automatic transmission oil & filter 160k / 120 months
Embarassed
Post #486101 14th Aug 2018 5:03pm
Thanks for posting back - first time I’ve seen a factual answer on this question Thumbs Up
Post #486108 14th Aug 2018 6:54pm
Hairy Dan
United Kingdom 2014 Range Rover Vogue SE SDV8 Luxor
I have uploaded the blank service sheets for a MY2014 TDV8 for services from 16000 miles/12 months service > 160000 miles/120 months service Thumbs Up
They are all together in one PDF file
http://www.fullfatrr.com/gallery/albums/us...sheets.pdf Cheers Ian
Kielder 4x4 Safari
Post #486555 19th Aug 2018 12:29pm
MJGH
Well done that man Thumbs Up
Post #486558 19th Aug 2018 12:46pm
abuss
Switzerland 2013 Range Rover Autobiography 5.0 SC V8 Firenze Red
Funny thing with "lifetime" is......means it is ok until it breaks. Then that was it with "lifetime". Can be 100k, or 150k...or whatever.
I think it is worth to change oil of the gearbox, defenitly it will do no harm.
I asked for it at a swiss RR dealer: They told me abaout 1000 pounds, or 1500 Euro. 80 per litre oil, and they will have to change the oilpan, as the filter is integrated......
Post #486651 20th Aug 2018 12:21pm
