Home > Technical (L322) > air suspension problem ?
MR GLOVER
United Kingdom 2005 Range Rover Supercharged 4.2 SC V8 Buckingham Blue
Having a slight problem with suspension . When left over night the car is nearly down to bump stops in the morning, goes straight back up when started. I have put it in off road height, gone round all air struts with soapy water...no bubbles and no noise so have tried moving fuse 57 and left for 3 days . The front drivers side has gone down 2" and the other 3 wheels dropped half an inch . Does this prove a small leak in the strut or could it be something else ? any advice ? thanks Paul
Post #478949 20th May 2018 9:15am
Did you try lifting each corner (back to wheelarch lift) when if off road height?
If not an airbag, check all your height sensors are in place
Diagnostics might help pinpoint the problem... .
Post #478955 20th May 2018 11:14am
MR GLOVER
Just put fuse back in and dash display said( vehicle lifting slow) but got to off road height ? think a trip to garage might be needed
Post #478960 20th May 2018 12:27pm
Paul thornton
That's probably because all the air had drained from the system. They take a while to fill up again.
Post #478964 20th May 2018 12:56pm
MR GLOVER
Right got me self an iid tool got rid off historical faults (loads) Laughing have taken it for a run and got the suspension fault normal height only bong ! when i got home put in the iid tool and got
RLM-SUSPENSION
C1A10-64 (2E)
PRESSURE FLUCTUATES WHEN THE SYSTEM IS INACTIVE -ALGORITHM BASED FAILURE- SIGNAL PLAUSIBILITY FAILURE
AND
VDM VEHICLE DYNAMIC
U0132-87 (0Cool
LOST COMMUNICATION WITH RIDE LEVEL CONTROL MODULE -BUS SIGNAL/MESSAGE FAILURE MISSING A MESSAGE
Mean any thing to any one ? thanks paul
Post #479418 26th May 2018 5:20pm
Paul thornton
Sounds like you've got a leak to me.
Post #479421 26th May 2018 5:43pm
MR GLOVER
i know but its a slow silent one Thumbs Up
Post #479426 26th May 2018 7:08pm
Stormin
2003 Range Rover HSE Td6 Epsom Green
Check your reservoir under the sill, mine had a piece of wood stuck in it, causing slow leak Three things in a blokes life his dog,his car and a Cornish pasty,nothing else matters.
2010 Range Rover Vogue SE Santorini Black, Arabica Aniline seats
Previous cars
1973 Mini 1000
1971 Hillman Avenger
1975 Chrysler Sunbeam
1981 Ford Cortina
1985 Volvo 340
1989 VW Golf
1989 Volvo 240
1991 Volvo 240
1991 Jaguar Soveriegn
1996 BMW 730
2003 Honda CRV
1999 Jaguar Soveriegn
2003 Range Rover HSE Epson Green with Sand trim.
Post #479535 28th May 2018 1:48pm
MR GLOVER
Can only see the bottom of the reservoir but it has wax oil all over it. it may have a leak on top ? just glad i have the iid tool now can keep my eye on every thing. like all range rovers been driving it a couple of days and no problems ..........
Post #479561 28th May 2018 7:19pm
MR GLOVER
well for some reason its all back to normal for now............................................
Post #479878 1st Jun 2018 1:33pm
