Home > Technical (L322) > 2010 Autobiography, tow tongue fitment?
Page 1 of 3 123>
Grizzly_Adams
Australia 2010 Range Rover Autobiography 5.0 SC V8 Barolo Black
G'day all,
I have recently purchased a 2010 Autobiography and am dealing with some of the left-overs of the previous owner.
I am really confused about the rear tow hitch assembly and am hoping someone can shed some light.
I am in Australia so I believe the tow hitch assembly is a Hayman Reese job so it's quite recessed under the Rangie.
However to me it looks like the previous owner has done a grinder-job to access it (see photos), and even though I have now sourced the official Hayman Reese 21181 tow tongue it doesn't go in far enough to put the pin in.
Can any offer any photos of their towbar assembly or advice on what should have been done so I can correct this and get the towing sorted?
Part II of the towing would be to try and swap the 7-pin large round adapter for a 7-pin flat and tuck it up out the way - but that's for another day.
Thanks!
Post #478332 14th May 2018 9:15am
Tinman
United Kingdom 2017 Range Rover Autobiography SDV8 Silicon Silver
HI, mate it looks like the same as the Westfaila fitting which has two types ie square with drop plate for adjustment standard 50mm ball or holder to take a detachable swan neck see Landrover Accessories? hope that helps
Post #478346 14th May 2018 11:54am
Looks a little high for the standard one and the neck is too short - neat installation job though Whistle
There’s a good pic of standard here
Post #478358 14th May 2018 2:01pm
bertie1
United Kingdom 2004 Range Rover Vogue Td6 Adriatic Blue
never seen a cut bumper before pure cowboy
Post #478362 14th May 2018 3:26pm
isn't that a sport?
OP Might find more help on the RRS forum Thumbs Up
www.rrsport.co.uk
edit... possibly not, the silencers were putting me off......bur never seen that arrangement is something I've not seen before!! There is nothing that can't be fixed with a hammer😜😜
Last edited by northernmonkeyjones on 14th May 2018 5:26pm. Edited 1 time in total
Post #478368 14th May 2018 4:52pm
A Sport has a spare wheel underneath doesn't it ?
Post #478371 14th May 2018 5:24pm
quite right, realised that....twas the silencers that put me off.
if you go on the Hayman Reese site their product catalogue doesn't cover an l322. There is nothing that can't be fixed with a hammer😜😜
Post #478372 14th May 2018 5:27pm
rjff
Hi, I can't identify your bar, but I hope this helps
Some photos of the bar on our 2011 model year and is the same unit as fitted as original, although ours is was purchased recently. You will see the bar sits below the bumper and replaces the parts assisting in holding the bumper (I think) and the recovery towing eye.
The swan neck holder remains in place, usually, but may be replaced with a ball hitch and tube. You will note there is no lower bolt fitted as in yours, the retaining bolts/pins being from the side. It may be that someone has done a lash up, as it appears there is a hole part way into your socket as in ours, but the length of the socket appears to be less than the Wesphalia. Links below to some info on originals.
https://www.westfalia-automotive.com/filea...320039.pdf
https://www.pfjones.co.uk/range-rover-towb...-only.html
Let me know if you would like further pics of the fitting locations, happy to do so. It may help in your quest for an answer.
cheers
Richard
Post #478389 14th May 2018 7:21pm
Grizzly_Adams
Thanks fella's, yeah she's a real cowboy job all right Evil or Very Mad Not good at all. Hard to believe someone probably paid for that work - and yes she's definitely a L322, someone's done some work with the exhaust also Shocked
Thanks Richard for the photos and information, they're both extremely helpful Thumbs Up I'll dig around underneath a bit more and see if I can confirm she is Westfalia Neutral
That grinder job just sends shivers up and down my spine Big Cry If it is a westfalia, I'm guessing who installed it hadn't seen one before Confused
Post #478406 14th May 2018 8:33pm
p38arover
Australia
Glenn, when the L322 sales began in Oz, all came with factory fitted Westfalia tow bars. Mine did but I don't Know about your year though.
That's a lovely hack! Ron B. VK2OTC
2003 L322 V8 Auto
2007 Yamaha XJR1300
Post #478424 14th May 2018 10:24pm
p38arover
Australia
Is that the right bar or is your rear air dam different to mine?.
My towbar drops in the middle:
Edit, looking at your first pic, it appears yours does, too. Now why is yours different to Richard's and mine. Our model years span yours. I do note your exhaust is different to both Richard's and mine.
Glenn, look for this sticker on the RHS.
The towbar now has the towing eye, you can just make it out below the RH reflector.
I'll go and photograph/measure the gooseneck on mine..........
Here we are (for non-Aussie viewers, this is the standard style gooseneck in Oz. The P38A had the same style).
 Ron B. VK2OTC
2003 L322 V8 Auto
2007 Yamaha XJR1300
Post #478432 15th May 2018 12:17am
wayneg
Australia 2007 Range Rover Vogue SE TDV8 Java Black
I see no reason not to remove a bit from the end, I have done that before with no ill effects. Can you see how far the hole is out, you should be able to mark it with a permanent marker. Mine is the exact same as the others in Aus.
One of my P38s (a 2002) never had a tow bar fitted when I purchased it. There was a hard plastic cover that needed to be removed and discarded before fitting the towbar. Maybe the L322 was the same and the installer tried to fit it back on over the bar? 2007 TDV8 VSE
2003 TD6 gone.
2002 P38a gone
1999 P38a gone
1997 p38a gone
1993 VSE gone
1992 VSE gone
1966 Series 2a with V8 conversion gone
Post #478433 15th May 2018 2:11am
Grizzly_Adams
Thanks Ron, that information and photos are very helpful Thumbs Up
That gooseneck you have is exactly the one that I sourced and isn't long enough to go straight in (not to mention the jigsaw action on the rear drop-down bumperette thingy)
Wayne I'm not sure which bit from the end you are referring to?
Post #478434 15th May 2018 3:45am
p38arover
Australia
Glenn, I wonder if your towbar was removed and relocated to clear the modified exhausts?
As a matter of interest, does you car have the recovery loop on the RHS? It's part of the towbar assy. See my pic. Ron B. VK2OTC
2003 L322 V8 Auto
2007 Yamaha XJR1300
Post #478435 15th May 2018 4:25am
wayneg
You say the tongue does not go in far enough for the pin hole to line up ? Cut the require piece off the end of the tongue and the hole will go in further. 2007 TDV8 VSE
2003 TD6 gone.
2002 P38a gone
1999 P38a gone
1997 p38a gone
1993 VSE gone
1992 VSE gone
Post #478436 15th May 2018 4:32am
Page 1 of 3 123>
