Home > Technical (L322) > 2010 Autobiography, tow tongue fitment? |
Grizzly_Adams Member Since: 11 Dec 2017 Location: Brisbane Posts: 36 |
G'day all,
14th May 2018 9:15am |
Tinman Member Since: 22 Mar 2017 Location: kent Posts: 1188 |
HI, mate it looks like the same as the Westfaila fitting which has two types ie square with drop plate for adjustment standard 50mm ball or holder to take a detachable swan neck see Landrover Accessories? hope that helps |
14th May 2018 11:54am |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7935 |
Looks a little high for the standard one and the neck is too short - neat installation job though
14th May 2018 2:01pm |
bertie1 Member Since: 30 Sep 2017 Location: kent Posts: 100 |
never seen a cut bumper before pure cowboy |
14th May 2018 3:26pm |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8517 |
isn't that a sport?
14th May 2018 4:52pm |
A Sport has a spare wheel underneath doesn't it ? |
14th May 2018 5:24pm |
rjff Member Since: 28 Oct 2017 Location: Cambridgeshire Posts: 1196 |
Hi, I can't identify your bar, but I hope this helps
14th May 2018 7:21pm |
Thanks fella's, yeah she's a real cowboy job all right Not good at all. Hard to believe someone probably paid for that work - and yes she's definitely a L322, someone's done some work with the exhaust also
14th May 2018 8:33pm |
p38arover Member Since: 16 Dec 2015 Location: Western Sydney Posts: 1529 |
Glenn, when the L322 sales began in Oz, all came with factory fitted Westfalia tow bars. Mine did but I don't Know about your year though.
14th May 2018 10:24pm |
Is that the right bar or is your rear air dam different to mine?.
Glenn, look for this sticker on the RHS.
The towbar now has the towing eye, you can just make it out below the RH reflector.
I'll go and photograph/measure the gooseneck on mine.......... Here we are (for non-Aussie viewers, this is the standard style gooseneck in Oz. The P38A had the same style). 2003 L322 V8 Auto 2007 Yamaha XJR1300 Previous: 1983, 1986 RRC; 1995, 1996 P38A; 1995 Disco1; 1984 V8 County 110; Series IIA |
15th May 2018 12:17am |
wayneg Member Since: 05 Jun 2013 Location: South Fremantle, Australia ( ex London ) Posts: 797 |
I see no reason not to remove a bit from the end, I have done that before with no ill effects. Can you see how far the hole is out, you should be able to mark it with a permanent marker. Mine is the exact same as the others in Aus.
15th May 2018 2:11am |
Thanks Ron, that information and photos are very helpful
15th May 2018 3:45am |
Glenn, I wonder if your towbar was removed and relocated to clear the modified exhausts?
15th May 2018 4:25am |
You say the tongue does not go in far enough for the pin hole to line up ? Cut the require piece off the end of the tongue and the hole will go in further. 2007 TDV8 VSE 2003 TD6 gone. 2002 P38a gone 1999 P38a gone 1997 p38a gone 1993 VSE gone 1992 VSE gone 1966 Series 2a with V8 conversion gone |
15th May 2018 4:32am |
