![]() | Home > Maintenance & Mods (L322) > Rear Light Cluster |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7976 ![]() ![]() ![]() |
Yes - undo the 2 on the inside and it should slide towards you - may need a little leverage if its been there for a long time. |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8689 ![]() ![]() ![]() |
There is two prongs on the back of he light which go into grommets on the rear wing. Take out the bolts and the light basically slides out backwards. The indents should be on the light on the rear wing edge. |
I cut a thin wedge out of softwood and then tapped it in the gap to gently drive the lights forward and off the clips. No damage to anything. I would suggest greasing the clips before putting the lights back in place, makes it easier to remove next time. |
p38arover Member Since: 16 Dec 2015 Location: Western Sydney Posts: 1547 ![]() ![]() |
The socket into which the ball joint slides (on my 2004, at least) can become brittle with age. Mine broke when levering the light out. Ron B. VK2OTC
SinbadRose Member Since: 21 Aug 2017 Location: Merseyside Posts: 114 ![]() ![]() ![]() |
Thanks for the quick reply's guys, I will go and sort it while we have sun light in the north |
Is the unit fully sealed, or do you just undo the 4 t20's and it opens? |
Left the bolts, used hot air to go through the 2 holes after removing the rubber covers on the back, all dry, resealed and fitted back, cheers guys |
