Home > Technical (L322) > Any idea what these are?
cheezels
Australia 2007 Range Rover Vogue TDV8 Java Black
Changed my front discs and pads and found these on the axle shaft, between the wheel and disc.
They look a bit worse for wear, but I can’t find a part number to order replacements.
Anyone any idea what they are?
Will the sky fall in without them??
 2007 3.6 TDV8
Post #477171 30th Apr 2018 8:00am
Pawl
England 2007 Range Rover Vogue TDV8 Cairns Blue
Does the car have non standard wheels ?
Could they be centralising spigot rings which should fit on the hub to locate the wheel better.
Otherwise no idea - certainly nothing like that on our 2006 TDV8 when I did the brakes & suspension arms recently Paul,
2001 Discovery 2 TD5, 211,000 miles & climbing
2006 FFRR TDV8 Vogue 145,000 miles & climbing
Member of Midland (Land) Rover Owners Club, www.mroc.co.uk
Post #477173 30th Apr 2018 8:09am
cheezels
Hmmm. There was fitted after market wheels when I bought it, but I refitted the original wheels soon after.
So, you might be onto something there.
I’m assuming the standard wheels are ‘centralised’ due to the tapered nuts? 2007 3.6 TDV8
Post #477177 30th Apr 2018 8:38am
Pawl
The correct standard wheels should be a "snug" fit on the hub centre ( which is why they can sometimes require a knock to get them off if the wheel or hub has corroded)
The standard wheel nuts on an L322 don't have a taper to help centralise if I remember correctly
(unlike our Discovery 2 which has a small taper) Paul,
Post #477180 30th Apr 2018 8:52am
there is a slight taper of sorts,
Post #477184 30th Apr 2018 8:55am
j_rov
+1 for spigot rings. __
2018 L405 3.0 TDV6 Vogue SE Fuji White
2000 4.6 V8 HSE Oxford Blue
1994 3.9 V8 Vogue Ardennes Green - resto project
Land Rover History:
2010 3.6 TDV8 Autobiography Stornoway Grey
2001 Discovery 2 TD5 GS
1999 Discovery 2 V8i XS
1994 Discovery 300Tdi
1993 Discovery 200Tdi
1989 Range Rover Vogue SE 3.5EFi
1976 Series 3 2.25
1977 Range Rover 2 door 3.5 Carb
Post #477185 30th Apr 2018 8:59am
cheezels
Ok thanks for that chaps.
Sooo, I don’t need them with the original wheels fitted? 2007 3.6 TDV8
Post #477188 30th Apr 2018 9:10am
Pawl
If you're back on standard L322 wheels - Not needed.
If you've got wheels from another Land Rover product, it would be worth checking if the wheel locates well on the hub before the nuts are fitted.
If a snug fitted, not needed. If a sloppy fit, they may be a benefit for centralisation, so try with them fitted. Paul,
Post #477191 30th Apr 2018 9:29am
nope Wink ... - .- -.
Post #477192 30th Apr 2018 9:29am
