Home > Maintenance & Mods (L322) > Sounds like old fashioned fan belt slip
Rambles
2011 Range Rover Vogue SE TDV8 Stornoway Grey
Engine still running fine....
And belt slip can only be heard outside the RR
What belts should I ask the indie to change?
Post #473789 25th Mar 2018 8:55am
the one [s] which are slipping.....
Mr. Green Wink ... - .- -.
Post #473804 25th Mar 2018 10:58am
You may need to check the belt tensioners for effectiveness too (both or either Smile ) .
Post #473820 25th Mar 2018 1:43pm
mpirie
Yep, agree with Joe, it's most likely a dry bearing in either the belt tensioner or idler pulleys.
The problem is finding out which one needs replacing.
When you consider the amount of dismantling required to get there, it may be worth replacing all of them.
Mike
Post #473825 25th Mar 2018 3:23pm
SoggyBottoms
United Kingdom 2007 Range Rover Vogue Supercharged Zambezi Silver
I have a similar problem. how many hours should it take? I can't see it in the WSM
Post #473832 25th Mar 2018 4:16pm
carpcat
United Kingdom 2011 Range Rover Vogue SE TDV8 Santorini Black
I had 6 HRs labour on my bill to change tensioner and both belts Shocked Chris
Post #473836 25th Mar 2018 5:19pm
Rambles
What price for the tensioner and belts?
You don’t say so assume the idler pulley was left alone. Any reason you didn’t renew this whilst you were at it? Are they expensive ?
Post #473855 25th Mar 2018 6:29pm
carpcat
Genuine Tensioner & both belts were approx £200. All other pulleys were checked and didn’t need changing. Chris
Post #473865 25th Mar 2018 7:21pm
