Home > Maintenance & Mods (L405) > Help on wire that triggers high beams |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3973 |
I think what you need to do is check the voltage on the " main beam flap" wire with the headlights on main beam and then on dip beam. With a bit of luck the voltage will change from +12V to 0V as you switch from one setting to the other.
17th Mar 2018 8:13pm |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16284 |
I have fitted a light bar too and use the flapper motor power to run a 12v spot lamp relay, i found the light bar would start to flash/strobe and eventually knock/trip the LCM out without the relay... A cycle of the ignition would auto correct the LCM but still, be warned the LCM doesn’t like powering too much extra stuff |
17th Mar 2018 10:27pm |
wlee69 Member Since: 25 Mar 2017 Location: Groton, MA Posts: 6 |
17th Mar 2018 10:47pm |
How soon would the light bar start to flicker? was it after it was on for some amount of time? or was it from the relay going on and off (like if you have your lights on auto high)??
18th Mar 2018 12:52am |
I have to agree with Craig re using a relay. I personally wouldn't connect any additional bits to these cars without using a relay. I use a relay switched from the flap wire to switch a light bar without issue to date. |
18th Mar 2018 7:39am |
Mine is connected the same way. Connecting to the main flap is just to trigger the relay....the main battery is powering the actual light bar! Thx again for the help! |
18th Mar 2018 10:45am |
18th Mar 2018 10:51am |
The light bar would start to flicker around 30 seconds after start up WITHOUT using a relay, it would then knock the LCM out 10-20 seconds later... |
18th Mar 2018 1:52pm |
A quick thought, how do you wash your light bar if its behind the grille? |
I swapped out the grille and put in a different one to let more light through....as far as keeping the bar clean, I guess you just spray thru the grille? Too much of a pain to get the grille out each time....
3rd Apr 2018 12:01am |
Charles89 Member Since: 11 Nov 2018 Location: Leicester Posts: 268 |
This is something I intend to do. And I also want to use a 433mhz key fob, so I can then program this into my garage door opener in the car, giving me a stealth but still oem on off source inside the car.
18th Nov 2018 7:25am |
Dixy Member Since: 09 Apr 2009 Location: Somerset Posts: 1092 |
Wow, I like the look of that, is this an upgrade you offer Craig. letters not necessarily in the right order |
18th Nov 2018 9:39am |
Can anyone definitively help with what wire is needed to trigger? I have a huge flaw in my 433mhz build... while it works perfectly, I massively underestimated the interference potential from other 433mhz items... I.e. at work when they open the compound gates it's triggering my light bar, and I've had reports of a disco coming from behind my grill during the day.
17th Jan 2019 7:30pm |
I have figured this out by taking the plug off and using a volt meter to watch for a volt jump.
18th Jan 2019 12:40pm |
