Home > Technical (L322) > coolant loosing again 2011 tdv8!
Biker
Italy 2011 Range Rover Vogue TDV8 Santorini Black
Hi everybody, after two years the leakage is not fixed.
First cooling container and it's sensor changed: keep on leaking i don't know where, no water under the car.
Then heater first blocked working maximum even with car turned off!!! Battery replaced and i don't know which rele/sensor changed.
Again coolant loosing and heater non working: pressure test and electric heater valve changed. After one month again loosing coolant! Heater is working, luckly,it's very cold here.. Spent a lot of money and coolant level is low, please anni boy had similar issues? Thank you
Post #470327 28th Feb 2018 4:09am
