Home > For Sale & Wanted > [Wanted] Looking for a good priced l322 diesel |
archermav Member Since: 01 Jun 2015 Location: Black Country Posts: 345 |
Less then three grand for an L322. Might be doable mate, but doubt it will be a good one. |
27th Feb 2018 1:26pm |
b348xyx Member Since: 29 Sep 2016 Location: Kent Posts: 319 |
If you want a good one you will need to add a couple thousand to that budget otherwise you will be spending a few thousand putting it right. 2003 Range Rover 4.4 Litre V8 - Adriatic blue
28th Feb 2018 6:18pm |
Paul thornton Member Since: 23 Sep 2017 Location: Lancashire Posts: 545 |
Agreed. For a decent td6 you probably need to double that budget and remember these aren't cheap cars to run.
28th Feb 2018 7:41pm |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8501 |
As above they start t about that figure for slightly ropey ones, and go up from there. There are some out there on Ebay at that sort of money, but they are all looking a bit tired.
28th Feb 2018 7:57pm |
nicksaab Member Since: 28 May 2013 Location: Wimbledon and West Wales Posts: 560 |
Hey Danny, all I can say is read the many many buyer stories on here and look for the best one you can find. At this price range though you are going to be looking at some real unloved sheds and you could easily blow double your budget in your first year just maintaining it. As a P38 owner then you are well aware of the pitfalls, so go in with your eyes open. Unfortunately I reckon your budget is what most of us on here expect to use on annual maintenance and most of the cars on here are already well maintained and cherished!
2nd Mar 2018 4:04pm |
wack61 Member Since: 17 Nov 2017 Location: Cheshire Posts: 104 |
I bought a fixer upper 2003 TD6 for £1000 with a goosed engine which was 1/2 what it was worth but I still have over 3k in it fixed and running but it's 2 owner car with loads of history, gearbox done 3 years ago, suspension done last year ,never failed a test and the only advisories on any MOT were low tyres , now has a low mileage engine bought from a seen running BMW 330D
3rd Mar 2018 6:22pm |
mrblonde Member Since: 24 Jan 2012 Location: Cambs Posts: 728 |
As above, nearer £5 for one thats half decent. If it needs a new/recon box that'll cost maybe £1,500 straight away so your £3000 is already £4500 |
10th Mar 2018 5:22pm |
