Home > Duckworth Parts > Stop Start battery - L405
Mariana Black
England 2014 Range Rover Autobiography TDV6 Mariana Black
Hi Dan
I am after a price for the stop start boot side panel battery from my 2014M5 autobiography.
I believe the number on the battery is CX23-10C655-AC
12volt / 14Ah200A
Once I open the door and get inside the dash is saying battery low and "need to start the engine". The stop start function is not working nor is the preheater. Not sure what else uses this battery?
Can you give me a price please. Is this a simple change or does it need coding from the dealer once fitted?
Many thanks for your time
Post #464712 15th Jan 2018 9:28pm
duckworthparts
Site Sponsor
I can no longer send batteries by courier unfortunately. You can paypal direct using - www.paypal.me/duckworthparts
Please supply your full name address when sending a paypal payment.
https://www.facebook.com/duckworthparts
www.duckworthparts.co.uk
My Direct Line: 01673 849873
Email: robin.hall@duckworth.co.uk
Supplier of Genuine Land Rover & Jaguar Parts For All Models
Post #464783 16th Jan 2018 4:36pm
Lad
England 2010 Range Rover Vogue SE TDV8 Santorini Black
Have the Range Rover checked as the monitoring system may be at fault. We had the same fault with our disco sport. We only have one battery but came up with the same message, and the auto/electric boot wouldn’t work. Thumbs Up
Post #464842 16th Jan 2018 11:49pm
DannyH
England 2002 Range Rover HSE 4.4 V8 Zambezi Silver
Try this place for the battery, I got my L322 battery from here and not had a problem with it.
https://www.tayna.co.uk/ Dan
2002 Zambezi Silver
Men And Motors RR Quote - It's like having wheels fitted to your living room!
Post #464970 18th Jan 2018 7:25am
Mariana Black
Hi
Many thanks for the replies. Thumbs Up
I have connected a multimeter on the stop / start battery and this has never dropped passed 12 volts.
I tried this morning the pre heat has again all failed - No heat and when I open the door the interior lights stopped working and the message was on the dash again but the stop start battery in the side panel was still ok. This means either a faulty voltage stabiliser or the main battery under the wheel is breaking down. Shocked
I will try the same process with the multimeter on the main battery and see what happens. Question
Thanks for any more replies
3.0 Autobiography 14M5
Post #465194 19th Jan 2018 10:52pm
jumpin mouse
United Kingdom 2015 Range Rover Autobiography SDV8 Aruba
Not attempting to hi-jack this post but if the OP's 2014 has stop/start, why doesn't my MY2015 (December 2014) have it? Maybe because I have a 4.4 SDV8?
I'm just curious, not necessarily missing stop/start as I know that's contentious in itself.
Post #465222 20th Jan 2018 11:04am
Pfazz
2019 Range Rover Autobiography SDV8 Loire Blue
Showing 12 volts on the battery is not sufficient. a fully charged battery should be in excess of 14.5 volts and not drop below 12.6 volts approx. Agueroooooooooo. 93-20
I swear you will never see anything like this ever again....watch it..drink it in.
Post #465229 20th Jan 2018 12:25pm
