Home > Technical (L322) > Battery drain and telephone module
NVB
United Kingdom 2004 Range Rover Vogue Td6 Cairns Blue
I have been working through trying to get to the bottom of a 240mA parasitic drain that was killing my battery in a few days. I have more to check, but have so far reduced the drain down to around 90mA just by removing fuse 22, which is for the telephone module. Now I am happy to just leave it disconnected, but it has thrown the whole MOST system out, and all I get with the fuse removed is the land rover holding screen and a flashing button.
Is there a way of removing the telephone module from the system, but leave everything else working?
The alternative, I guess, is a replacement module.
Cheers RR History
1988 2.4td Classic 1999 to 2020
1992 3.9efi Westminster Classic 2004-2005
2005MY L322 3.0TD6 Vogue 2016 to current
Post #464784 16th Jan 2018 4:37pm
zarnd
United Kingdom 2005 Range Rover Vogue SE 4.2 SC V8 Bonatti Grey
Take the MOST wires out and use part of a biro tube so that they face each other and it should then work. Tape it together and it will bypass the phone module and allow everything else to work. I have had to do this for the second time today due to a water leak in the rear that looks to have taken out my Bluetooth module and had the same issue with just the LR screen and flashing orange button.
cheers Alex
2018 Skoda Kodiaq vRS
2009 Caterham Supersport Race car
2007 M5 Touring
2005 Range Rover Vogue SE Supercharged
2004 SL55 AMG
Post #464789 16th Jan 2018 5:29pm
NVB
Thanks, I'll give that a go. RR History
Post #464836 16th Jan 2018 11:16pm
