Home > Technical (L322) > DPF ADVICE PLEASE...
kgeddes
United Kingdom 2013 Range Rover Autobiography SDV8 Causeway Grey
My 2010 3.6 tdv8 has covered 64000 miles and has been used very much as a ‘Chelsea Tractor’ by its previous owners since new. I do a lot of short (2 miles or less) journeys Monday to Friday. How often should I take it for a 50mph + run and for how long to keep the DPF functioning properly?
Thanks in advance.
Post #463916 9th Jan 2018 2:52pm
just run as you do now....if and when the yellow dpf warning comes up then run it at 50mph for about 10-20 minutes to clear it..
i to use mine for mainly short journeys and its only come up once about a year ago... ... - .- -.
Post #463920 9th Jan 2018 3:31pm
SinbadRose
I got the yellow warning last October. Once the engine was warm, I used a little more right foot for acceleration while keeping it in lower gears Whistle (in the lakes at the time) for around 10-15 mins, that cleared it for me, just needs to get hot.
Post #463927 9th Jan 2018 4:45pm
GAC23
United Kingdom 2015 Range Rover Vogue SE SDV8 Indus Silver
I too do lots of short runs.
Stan's advice worked for me.
Just let the engine get up to temperature then go for your 50mph+ drive.
Holding the car in lower gears to get the revs up - as some people advised me - doesn't need to be done. What do I put here then?
Post #463928 9th Jan 2018 4:50pm
fisha
tI found in my freelander than ragging the nuts off the engine to clear the DPF was a waste of time. As mentioned above, driving normally between 50 and 70-mph seemed to be far more effective at clearing it.
I think its to do with a cruising speeds and normal engine revs, there is more overhead in the exhaust system to allow it to dump fuel down and burn out the DPF to clear it. Ragging it reduces that overhead. V8 or else ...
Post #463929 9th Jan 2018 5:23pm
GavinBell
Romania 2012 Range Rover Westminster 4.4 V8 Santorini Black
Lost my DPF cherry today
The dreaded warning came on for the first time in my ownership.....
After initail stress.... took it for a run the long way home on our ring road - we dont actually have a motorway here yet. Luckily on first section the police were on the other direction - so wound her up to a steady 60-70mph and by the 15 km at t'other end , with a few slows for roundabout, the warning ! disappeared.
Luckily heading to Serbia on Friday - for Serb/Russian Mew Year and my Grandaughters 2nd bday.... so this should a give run to clear out properly. Series 2a LWB Hardtop - ex British Aerospace that was then used in an armed robbery! not by me!
2 door V8 1979 Range Rover
A slight Subaru blip..
110 County 200tdi
R reg 300 tdi Discovery Aviemore - gone to a local enthusiast to be resurrected in Transylvania
2003 TD5 Discovery2 - now sold
and the 2 wheeled Range Rover - BMW R 1150GSA
and finally the big lady of my dreams... 2012 Westminster - gives me a smile every morning
Post #463930 9th Jan 2018 5:39pm
Rambles
Is DPF regeneration silent ?
Post #463941 9th Jan 2018 8:11pm
if it does make a sound you wouldnt hear it over the engine/road noise.... ... - .- -.
Post #463942 9th Jan 2018 8:16pm
kgeddes
Thank you for the replies, very helpful Thumbs Up
Post #463955 10th Jan 2018 12:14am
peejay
England 2009 Range Rover Vogue SE TDV8 Santorini Black
I didn't think the TDV8 3.6 had a DPF, I thought it was only introduced in the 4.4?
Post #464007 10th Jan 2018 2:56pm
it was optional,
from the WM,
Post #464010 10th Jan 2018 3:19pm
