Home > Maintenance & Mods (L322) > Tow hitch mounted motorcycle carrier - any recommendations? |
m@ttsFF Member Since: 12 Dec 2017 Location: Surrey Posts: 327 |
Morning chaps
5th Jan 2018 10:21am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35281 |
have you tried here,
5th Jan 2018 12:08pm |
Thanks Stan , Watling are on the list to contact along with Dave Cooper if I can’t find one off the shelf
6th Jan 2018 7:52pm |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8508 |
The max tow ball weight is 150kg in the UK, but for some bizarre reason it’s higher in other countries, 350kg I think in Australia for example. Have a read of the towing weights in the manual. There something about increasing this in certain situations. There is nothing that can't be fixed with a hammer😜😜
6th Jan 2018 8:15pm |
Clivefog Member Since: 23 Aug 2015 Location: Bristol Posts: 354 |
Dave Cooper works fine for my Garelli.
7th Jan 2018 9:56am |
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1350 |
The general nose weight seems to be 150kg, but when you read the label on my towbar it says it's dynamic load rating is along the lines of 17000kg (or is it kN ? Can't quite remember) ... So I'd guess there is a bit more scope for more than 150kg. V8 or else ... |
7th Jan 2018 6:56pm |
KurtVerbose Member Since: 08 Aug 2010 Location: Les Arses Posts: 5848 |
Interesting.
7th Jan 2018 7:15pm |
After a little more research , an additional 100kg on the tongue weight is fine as long as it is counted in the MGW . So 250kg or 550lbs is permitted ( including the weight of the carrier)
7th Jan 2018 8:29pm |
Looks fab. |
7th Jan 2018 10:10pm |
I went with the US model a# I couldn’t find one locally
24th Feb 2018 2:54pm |
ffaffage Member Since: 12 Aug 2019 Location: Hampshire Posts: 19 |
Now you've had this for a while, how are you finding it? I'm thinking of something similar for my trail bike, but my main concern is that I think the 2 inch hitch is tucked further under the vehicle than normal on US cars, so the bike may end up a bit close to the rear of the RR.
3rd Nov 2019 9:45am |
It’s a great bit of kit and a permanent fixture of late .
3rd Nov 2019 11:14am |
OK, thanks - it's encouraging that you haven't decided it was a bad idea. The length thing only occurred to me because I picked up a Thule bicycle rack (very cheap on eBay as no-one wants 2 inch hitch stuff here), but I had to modify that to fit. Luckily it had a 1 1/4 to 2 inch sleeve, so I could slide that out a bit and drill a new hole. That's fine with a bicycle rack with a light bike on it, I'd be a bit more worried about a motorbike that weighs much more than ten times as much. I'm happy with a welder, but not so confident when it comes to something so critical.
3rd Nov 2019 2:56pm |
