Home > Maintenance & Mods (L322) > Door Squeak
SinbadRose
Door Squeak
Started to get a squeak when I open the driver door, as it was dark, I just gave it a quick spray with white grease. On closer inspection as it carried on, it is rubbing on what looks and feels like a chunk of sponge coming from under the front wing at the top. Is this noise reduction insulation, or is it something that shouldn’t be there, and someone has done a quick fix to hide something?
Post #461402 19th Dec 2017 11:46am
mine got wobbly and the dealer fitted new ones ,the rubbers can be re-stuck though..
Post #461404 19th Dec 2017 11:51am
SinbadRose
may have to give it a trim, as it feel stuck down where it is Sad
Post #461405 19th Dec 2017 11:59am
Dolphinboy
Check all the nuts are tight on the door swivel mechanism. My first FFRR had a squeak and tightening the nuts and bolts cured it.
Post #461408 19th Dec 2017 12:13pm
SinbadRose
Thanks for that guys, will do a full check this weekend. Not a major issue, just one of those things you don't think about until the next time you have to get in or out.
Post #461428 19th Dec 2017 1:51pm
