![]() | Home > Maintenance & Mods (L322) > Air suspension inactive and HDC warning after Strut replace |
doclees Member Since: 24 Jun 2015 Location: PA Posts: 672 ![]() ![]() ![]() |
Using the iidtool I deflated the system, changed the struts and then re-inflated with the re-enable EAS function. I'm not sure I completed it correctly. There was no notification that the re-enable was completed. Now I'm getting the listed error messages on the display. System seems to be holding air and height. Front R and L are off by about 1/2 inch. Any suggestions? |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2575 ![]() ![]() ![]() |
With HDC inactive I suspect an ABS sensor fault as that will also trigger a suspension fault. |
UK Marine Member Since: 22 Jul 2016 Location: Durham, County Durham UK Posts: 830 ![]() ![]() ![]() |
Have you done the steering fully left then fully right? It could be something as simple as that... ______________________________
I'll try it today but why would it be necessary? Battery was not disconnected. Track rods weren't disconnected. ABS sensors weren't disconnected. |
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1426 ![]() ![]() |
maybe it just knows that the system has been worked on.... they are fickle things.
No disconnect of ABS but you need to remove the lines from the strut holder. Yesterday when the wife had the RR is when the warnings came on. I had only put about 15 miles on it before this and hadn't gone over 35 MPH. I cleared the codes when she got back. This morning had to go about 30 miles on highway. I did the left right steering wheel turn before heading out. No warnings yet. It wouldn't drop to highway height until I held 70 MPH for about 1 min. So I'm guessing I haven't actually damaged sensor in the refit. |
