Home > Maintenance & Mods (L322) > Roof rack
Balloonengineer
Roof rack
Hi All
Being always frustrated with safely tying things to a roofrack and stop things sliding sideways I made these.
They also fit my jaguar roof bars, so I guess the aluminium extrusion Tee slots are fairly standard size.
I milled them square from coach bolts, then made a nylon spacer washer with a square hole to fit the bolt shank, then some M10 eyenuts. I believe you can get factory M6 ones, but look micky mouse weak, so something decently strong had to be made.
Best wishes
Glen
Post #459023 30th Nov 2017 10:47am
Giantlandyman
United Kingdom 2012 Range Rover Autobiography TDV8 Santorini Black
Now that is a great idea well executed.
Well done that man.
Post #459083 30th Nov 2017 7:31pm
Paulus1978
England 2008 Range Rover Vogue SE TDV8 Santorini Black
Nice job!
You must be 7' tall if you can reach the roof to put anything up there Laughing I have to get the step ladder out to wash and polish the roof.
Post #459085 30th Nov 2017 7:35pm
wood78987
United Kingdom 2012 Range Rover Westminster TDV8 Stornoway Grey
Brilliant idea Thumbs Up 2012 Westminster 4.4 TDV8
Post #459086 30th Nov 2017 7:51pm
Sandyt
Like that Thumbs Up Thumbs Up
Post #459088 30th Nov 2017 7:54pm
Balloonengineer
Thanks for your kind words. I am lucky I have a lathe and a milling machine and sometimes you get dragged along the fun of trying to do a nice engineering job.
But for DIY they could be made almost as well with an angle or bench grinder (or even a file.....!), take off a bit of the dome head, and put 2 or 4 flats on the edges. to make it 20-21mm. (its square to stop it unscrewing)
The nylon washer (square bore) could have a round bore, or be hard rubber, but its nicer square as it self centers.
Anybody got a 3D printer could add it to the LR forum shop!
M10 eye nuts off ebay @£1.49p each delivered. Stainless if you are posh.
As I mentioned, it also fits my Jag roof bars, so twice the use!
Best wishes
Glen
Post #459097 30th Nov 2017 8:30pm
Wogger
England 2010 Range Rover Vogue TDV8 Orkney Grey
Got them on my aero bars, they make them as an accessory.
Very useful Thumbs Up
Post #459099 30th Nov 2017 8:33pm
