Home > Maintenance & Mods (L322) > 4.2 s/c vs 4.4 m62 |
holidaychicken Member Since: 06 Nov 2013 Location: Kent Posts: 1086 |
I have the 4.4 and I only have the amount of threads I read about problems as experience and so I would say the SC is both more reliable and more efficient having the supercharger.
23rd Nov 2017 1:25am |
Blair Member Since: 03 Apr 2017 Location: Suffolk Posts: 72 |
In terms of running costs, they're not wildly different. The AJV8 is a bit more modern, and probably the best engine fitted to any RR in terms of reliability against performance.
23rd Nov 2017 7:19am |
Paul thornton Member Since: 23 Sep 2017 Location: Lancashire Posts: 545 |
Does the 4.2 have the same chocolate gearbox as the td6? |
23rd Nov 2017 8:53am |
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1340 |
No it has the later mych improved 6 speed |
23rd Nov 2017 9:19am |
No it has the later much improved 6 speed |
Mulcher Member Since: 08 Aug 2016 Location: Shropshire Posts: 240 |
No, it has the ZF 6HP26 which is a 6-speed box which seems pretty good if you ignore JLR's "sealed for life" bull about the transmission oil. 2006MY 4.2 SC
23rd Nov 2017 9:20am |
Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2257 |
The gearbox is fine the solenoids can be temperamental but most issued solved by changing fluid - I change mine every 30 to 40k |
23rd Nov 2017 9:44am |
Danwilderspin Member Since: 15 Jun 2016 Location: Cambridgeshire Posts: 2215 |
great thanks guys - now i will ask the dreaded question - are they that much worse on leg in terms of reliability? Current stable:
23rd Nov 2017 9:49am |
also - a little earlier than I'm looking but do the 2005 models still use any of the bmw components like bus or anything as the interior is pretty much the same? Current stable:
23rd Nov 2017 9:57am |
To give you an idea I have a couple of Range Rovers and my 4.2 I bout 4 years ago on just short of 80k miles it has now done nearly 165k in that time I have changed front struts and when I did that i changed the pump my choice but I tend to do preventative maintenance I have changed the water pump and all pulleys and belts last year as they were 10 years ol same with the battery to starter lead all working but could be an issue - I also replaced all bushes and ball joints at 125k - still drives like a dream - I do quite a few long runs to south of france so don't want any grief - it has never let me down I will change all the heat exchanger rads next year so in a nutshell fabulously reliable if you look after them and service them as per the schedule or more ignore bits and it will bite you - I also believe the one that are used daily and do miles are in much better condition that those left to do 30 miles a week |
23rd Nov 2017 10:00am |
The SC gearbox is much better than the TD6 unit, but can still suffer premature failure if not maintained. Mine failed at 96k. As others have said, ignore the LR service schedule for the gearbox, and replace oil and filter every 30-40k.
23rd Nov 2017 11:05am |
If i was buying a petrol one today i would opt for 5.0 SC, 4.2 SC and then the 4.4( don't tell my fatty tho) |
23rd Nov 2017 8:18pm |
kezbo1981 Member Since: 20 Jan 2015 Location: Evesham, Worc Posts: 334 |
My 4.2 SC is now on 207k miles! Gearbox was rebuild by a previous owner and then I got the solanoids sorted as the rebuild hadn't fixed it. Ive owned it for almost 3 years and it's had front struts, radiator, water pump, air con pump. But most of that is just age / mileage related as not specific to the SC spec. |
24th Nov 2017 5:38pm |
