Home > Maintenance & Mods (L405) > 2013 L405 electric tow bar.
Neil183
United Kingdom 2013 Range Rover Vogue SE SDV8 Causeway Grey
Hi.
I've just gone to use my tow bar for the first time and although the arm swings out OK, the pkug/socket stays hidden.
I seem to remember reading that this was common and there was an upgrade part available to replace seized socket arms?
Can anyone point me in the right direction please?
Thanks
Neil.
Post #458123 21st Nov 2017 6:50pm
Dinsdale
England 2016 Range Rover Vogue SE TDV6 Kaikoura Stone
Think it's this, which I have saved a print-out from somewhere, as my 2016 has the electric tow arm. Never a problem so far!
But do note you must NEVER fit a towball cover to it as there is not enough clearance when stowed.
I quote:-
" Issue:
A customer may report that the power/electrical socket for the EDT (electronic deplorable tow at) does not deploy when the bar is deployed.
Cause:
Under some conditions the tow power/electrical socket stays in the stowed position
(Yes, we bloody well know that 'cause that's what we've just complained about Shocked )
Action:
If the customer reports the power/electrical socket not deploying a service kit is now available, VPLGT0138, which replaces the existing part.
Post#403724 6th Sept 2016 7.33pm"
Hope that helps. Clearly a known problem. So may be under warranty.
I think this was an extract from a TOPIX bulletin. But no obvious TSB number etc. But it's obviously official.
Clive
Post #458152 21st Nov 2017 10:45pm
Neil183
Excellent, that's the one.
Ordered on eBay, £13. I'll let you know if this does the trick!
Many thanks.
Post #458155 21st Nov 2017 11:15pm
Fleagle_UK
United Kingdom 2014 Range Rover Autobiography SDV8 Luxor
LR issued Special Service Message SSM71359
Doesn't say much - just whats above really. No indication if its a customer pay or LR pay.
Post #458198 22nd Nov 2017 12:24pm
