Home > Technical (L322) > SatNav DVD Drive destroys disc!
GolfLima
United Kingdom 2006 Range Rover Vogue Td6 Epsom Green
Big Cry
Chaps,
Was driving to work this morning and the satnav in my MY06 FFRR (with the touch screen satnav) started to say "Nav disk read error" (or similar - I don't recall the exact words). A bit of button prodding and the moving map continued as normal. Then after about 10 minutes the display alternated between the "sat nav read error" and the normal moving map display all the way to work. I took the DVD out and was amazed to see the disk with concentric rings etched in and many scratches on the disk - it's as if the DVD drive has destroyed the disc!! I cleaned the disc as best I could, re-inserted it and then the satnav showed nothing at all, just the "error reading disk" screen.
Particularly annoying as I bought the disc from NavTeq last year in March for £149 (rather than going down the illegal/piracy route for free!).
When I got home I replaced the 09/10 disc with the original 06 disc and the sat nav appears to now be working. My worry is that over time the unit may trash this original disc too....plus of course ideally I'd like updated maps so will look to buy a new NavTeq DVD once the 2011 maps are released....but don't want to shell out another £149 if the disc will only last 8 months in the drive.
Any ideas or thoughts on what might have damaged the 09/10 disc and what do you think the chances are of it happenning again? I'm told by my local indy that the head units are v expensive to replace (circa £900) and that no cheaper OEM options are available, is this correct??
Thanks all,
- GL
Post #45782 12th Jan 2011 4:36pm
first of all make a copy of the original 2006 disc, then use that disc in the dvd drive..this means you have the original safe from damage...i dont know why the new disc got damaged unless the dvd drive is on its way out or maybe a large pothole vibrated something inside the drive...
Post #45784 12th Jan 2011 4:43pm
GolfLima
Hi Scarey,
Yes good tip - I've never had much joy with making DVD's so just tried to take your advice and make a copy but ran out of space on my 4.7Gb destination DVD-R. It looks like the NavTeq disc holds around 8Gb of data, so to make a copy of that will I need to use a DVD R/RW, DVD DL or DVD-RAM do you know?? ....or in other words, assuming a blank 8Gb DVD is available (I've yet to check) what type of disc will the RR drive read?
Thanks again for the tip - good one,
- GL
Post #45800 12th Jan 2011 6:03pm
you need a dual layer / double layer dvd disc and a laptop/pc capable of writing the same...i know from your post that you dont like illegal copies but if you get stuck and as you have the original disc, i can do a 2009/10 ''backup'' copy for you for a small charge..
Post #45802 12th Jan 2011 6:09pm
GolfLima
Sent you a PM ;0)
Post #45803 12th Jan 2011 6:13pm
igore
England 2002 Range Rover Vogue Td6 Adriatic Blue
hello scarey, a quick question for you. can you get up to date discs for the old mk 111 nav units ?
regards
ian ONE LIFE LIVE IT
Post #45863 13th Jan 2011 10:22am
SteveMFr
Site Sponsor
Don't exactly know how legal they are, but
http://www.bmw-maps.co.uk/
BTW, that would be the MK III vs the MK One-hundred-eleven? Laughing
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s
Post #45878 13th Jan 2011 1:52pm
Emperor Mong
United Kingdom 2019 Range Rover Autobiography 2.0 PHEV Loire Blue
How much would the update discs for my 07 cost?
Post #45881 13th Jan 2011 2:50pm
regards
ian
if thats the same as my sons 2002 bmw with the non-touch screen and cd drive then i believe i have a backup 2009 disc ....
Post #45883 13th Jan 2011 2:58pm
pm sent sir..
Post #45884 13th Jan 2011 3:03pm
T24RES
I just bought one from http://eurosatnav.com/ for my MY08 Ian
Post #45886 13th Jan 2011 3:06pm
from 2005 [with touch screen] the dvd's were different so this upgrade disc is only for pre 2005...
Post #45890 13th Jan 2011 3:09pm
T24RES
I got the later one as depicted by my little blue motor Wink Ian
Post #45894 13th Jan 2011 3:12pm
Post #45897 13th Jan 2011 3:15pm
mzplcg
scarey wrote:
pm sent sir..
erm, could you PM me as well please? Thumbs Up
Post #45915 13th Jan 2011 4:21pm
