![]() | Home > Technical (L322) > Rear Wash/Wipe - One-Way Valve? |
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6373 ![]() ![]() ![]() |
It all enclosed inside the motor, it's a one piece unit.
Philip Member Since: 05 Jan 2010 Location: UK Posts: 2604 ![]() ![]() |
Thanks - it's definitely not a blocked nozzle as it does eventually work as it should if you keep the stalk pushed for long enough. Will investigate further for hidden leaks.
Andy Member Since: 23 Feb 2009 Location: Shropshire Posts: 2944 ![]() ![]() ![]() |
I'm not getting any water to my rear screen. The motor sounds like its running intermittently when held? Sort of a stop/start. The front is fine.
SGW Member Since: 09 Sep 2009 Location: Headcorn Kent UK Posts: 77 ![]() ![]() ![]() |
On my 02 the inline non return valve is adjacent to the motor, when I replaced it a couple of years ago it was about £2.00. If on the later models it is integral to the motor you could cut the tube and use an inline one.
tomthevet Member Since: 14 Jan 2012 Location: Scotland Posts: 283 ![]() ![]() ![]() |
On a related note.....
nino_nino Member Since: 29 Mar 2015 Location: pocitelj Posts: 690 ![]() ![]() ![]() |
when the wiper starts to go down open the rear gate. it will stop the wiper arm. it will take some practice to get it right. |
chefkenmore Member Since: 11 Jan 2015 Location: Fearnan perthshire Posts: 750 ![]() ![]() ![]() |
Non return valve is situated just to the left of the wiper motor! It is not part of the wiper motor!! 2014 vogue se |
Clabs Member Since: 08 Mar 2017 Location: Watford, Herts Posts: 125 ![]() ![]() |
Great tip Nino - thank you |
Cheers for the tip!
