Home > In Car Electronics (L322) > iPad holder |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3542 |
front or back j-rov?
23rd Sep 2017 5:41pm |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8512 |
In the back yes, on some stanchion mounts, why would you want one in the front. There is nothing that can't be fixed with a hammer😜😜
23rd Sep 2017 7:01pm |
nav maybe for the front?
23rd Sep 2017 7:20pm |
j_rov Member Since: 10 Jan 2017 Location: Warwickshire Posts: 386 |
Front, for nav..... __
23rd Sep 2017 10:25pm |
There is the cup holder mount that nino nino posted:
I'm on the look myself, but after something a bit higher... Cheers, Greg - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - 2011 Vogue SE 4.4 with lots of toys in Stornaway |
24th Sep 2017 7:06am |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7796 |
Seems as I think you can get the cup holder inserts easily if you want to put your car back to normal, would it be possible to modify one of these and mount it firmly under the cup holders out of sight and have it coming out through one, if you see what I mean?
24th Sep 2017 7:25am |
obvs not a 322 so this would need some work to adapt - but what if it was on the dash-top?
24th Sep 2017 10:42am |
or this - very cool!
24th Sep 2017 10:44am |
That looks like it's obscuring vents and controls though...... 2011 Range Rover Vogue SE 4.4 TDV8
24th Sep 2017 10:46am |
I meant your first pic....
24th Sep 2017 10:48am |
Thanks all for the inspiration. I’ll post what I come up with in the end. __
24th Sep 2017 6:15pm |
If I was brave I'd get a trimmer to cut a slot here (dotted line) and have the iPad drop into a 20mm recess:
24th Sep 2017 6:57pm |
you'd have to be very brave to do that! Either that or good with leather... i could imagine it being made very pretty with the correct workmanship. __
24th Sep 2017 7:57pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35284 |
Gregs idea is a good one but rather than cut the trim i would use some kind of vent mount in the top vents.... ... - .- -.
24th Sep 2017 8:04pm |
