Home > Maintenance & Mods (L322) > 4.4tdv8- Anybody heard of leak cylinder head oil press. plug |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3542 |
This is exactly what was written:
18th Aug 2017 4:38am |
nino_nino Member Since: 29 Mar 2015 Location: pocitelj Posts: 690 |
gonna_go_double_r
19th Aug 2017 12:25pm |
ok thanks a lot nino.
21st Aug 2017 7:18pm |
do you get any oil in the antifreeze? |
21st Aug 2017 7:45pm |
err - didn't check... What is that from?
21st Aug 2017 8:03pm |
when i had O rings leak I also had leak from the oil cooler itself which was leaking oil to the outside but also inside into the antifreeze.ended up changing gaskets. check pictures i posted in the "4.4 TDV8 Oil Leak Fix". |
21st Aug 2017 8:26pm |
ok thanks Nino I'll check that out.
22nd Aug 2017 6:01am |
