Home > Maintenance & Mods (L322) > Can't access erm access height... {SOLVED}
UK Marine
England 2003 Range Rover Vogue 4.4 V8 Zambezi Silver
The cars been parked up for a time while waiting for me to order some bits up and to drain down the gearbox, anyway with it standing so long the battery started to flag so I swapped it out for my spare. Did the steering reset and set it to off-road height, it was struggling to get up to height so I popped it back to normal waited a few minutes and thought I'll drop it to access (I do this if the cars been standing a while so the air springs don't start to crack from lack of use). Anyway the suspension light for access wouldn't light up and the car didn't drop, so it struggled to raise to max and it won't drop to access - the IIDtool doesn't show any eas faults - any ideas guys...... ______________________________
Simon
Range Rover Classic 3.5 efi - Gone
Range Rover Classic 3.9 efi - Gone
Range Rover Classic 4.2 LSE - Sadly gone
Land Rover 110 3.5 - Gone
Range Rover P38a 4.0 SE - Pleased it's gone
Range Rover P38a 2.5 DHSE - Just sold
Range Rover L322 4.4 v8 Petrol - Current
Post #448200 17th Aug 2017 8:02pm
UK Marine
Bumpy 👍🏻 ______________________________
Simon
Post #448226 18th Aug 2017 8:00am
possibly not enough air in the system?..leave it running a bit longer ..
you did have the doors/tailgate closed i assume.. Wink ... - .- -.
Post #448228 18th Aug 2017 8:15am
UK Marine
I did have everything closed but a bit confused that the led for access height wouldn't light up.
I'll go up today and give it another go, it might just be a dodgy led.... ______________________________
Simon
Post #448230 18th Aug 2017 8:56am
zarnd
United Kingdom 2005 Range Rover Vogue SE 4.2 SC V8 Bonatti Grey
I had a fault with mine with no lights on the suspension module and unable to select any height.
I removed the exhaust from the compressor and it worked. I ended up getting a hole drilled in the exhaust so that the air would escape and I could then use the suspension properly all the time.
Worth checking and also easy to check as well!
cheers and good luck Alex
2018 Skoda Kodiaq vRS
2009 Caterham Supersport Race car
2007 M5 Touring
2005 Range Rover Vogue SE Supercharged
2004 SL55 AMG
Post #448232 18th Aug 2017 8:57am
Taking it for a drive might wake everything up Wink .
Post #448233 18th Aug 2017 9:14am
alistairh
I've just dealt with the same.. ended up having to do a battery reset to waken up the system again
Post #448236 18th Aug 2017 9:48am
UK Marine
Good advice lads.
I'll do reset then give it a drive out, mind you just noticed the n/s front tyre is flat so that might be knocking the system out of kilter.. ______________________________
Simon
Post #448239 18th Aug 2017 10:11am
Billaboard
United Kingdom 2004 Range Rover Vogue Td6 Baltic Blue
I'm a beginner on this squatting and lifting stuff, but I've now had the TD6 a fortnight and still haven't worked out what works and what doesn't.
The door switch seems to do nothing wrt the height. I assume this is a faulty switch or wire.
It seems to go a bit towards the off-road height when I switch the main switch that way, but it's hard to tell. Switching it down to the access position sometimes seems to do something, sometimes not a lot. It always seems to come back to normal ride height when set back to normal.
Whenever it moves, it feels as if the front goes up or down first. Is this normal?
Post #448252 18th Aug 2017 11:49am
bembo449
United Kingdom 2002 Range Rover Vogue Td6 Adriatic Blue
im with Alistair on this , drive it and it will sort itself out
Post #448256 18th Aug 2017 12:11pm
UK Marine
Just been up and all is ok, went down to access then straight up to off road height so god knows what was wrong yesterday.
But those of us with a 322 know that tomorrow is another day........ Thumbs Up
@ Billaboard - a previous owner of your Range Rover may have tinkered with the suspension heights, best to get it hooked up to an IIDtool and look what heights or faults are stored in the cars memory. Then take it from there..
Best of luck and thanks to everyone who suggested ways of helping me out... ______________________________
Simon
Post #448279 18th Aug 2017 2:11pm
bembo449
Billaboard wrote:
I'm a beginner on this squatting and lifting stuff, but I've now had the TD6 a fortnight and still haven't worked out what works and what doesn't......................................
there is most definitely not doing what it should , off road is a lot higher than normal and low doen is a lot lower than standard ride height , could be your compressor getting tired ?
Post #448284 18th Aug 2017 2:41pm
Billaboard
Thanks, both, for the replies. I'll add that to the list of things for the local indy to look at and start saving up.
Post #448307 18th Aug 2017 4:34pm
bembo449
if the compressor is getting tired its only 25 quid to refurb it and its not a difficult job at all pal
Post #448312 18th Aug 2017 4:46pm
UK Marine
Yeah I refurbed my P38a compressor a few times so I think I'll be doing this one as a precaution.
Cheers mate 👍🏻 ______________________________
Simon
Post #448318 18th Aug 2017 6:00pm
