![]() | Home > Technical (L322) > RQN500012 Air Reservior |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8687 ![]() ![]() ![]() |
looking at microcat it comes up with 2 different part numbers depending on VIN for the 2002-10 FFRR, RQN500020 and 500040 both of which are currently available.
Highroller Member Since: 18 Jul 2016 Location: Hampshire Posts: 565 ![]() ![]() ![]() |
Thanks for the reply.
Ah got you, looking closer at the vins, from 6A000001 up to 6A228699 uses the part you have specified, this then changed to RQN500013 for vins from 6A228700 to 8A274979.
Apparently LR don't list a replacement part.
As these are high pressure units you could assume that they have a pretty thick wall, I don't think many have reported leaks in the actual reservoirs.
That was my initial thought, however it is getting pretty crusty & If I take out I prefer to replace it.
RRBlue Member Since: 23 Feb 2012 Location: Cambs Posts: 222 ![]() ![]() ![]() |
See thread.
Thanks for update. I'll drop Dan a note. Luckily I still have a new set of steps sat in the box. |
