Home > Maintenance & Mods (L322) > Parcel Shelf - Broken Peg Repair
GGDR
Was heavy handed with the parcel shelf the other day and snapped off one of the guide pegs. It's one of the end pegs nearest the tailgate end so the peg takes any load on the shelf.
Viewed from the underside of the shelf, here's the fella snapped off:
So I got a 4x50 screwfix screw and drove it into the shelf. There's a hole and some solid material so the screw seems to hold in there nicely. I used my DeWalt driver with a clutch setting of 6 so it would bite in enough but not more.
Then cut off the screwed with the Dremel, making a bit of a point while I was there.
Next I took the broken-off peg and ran a drill through the existing hole, 3.5mm drill or 4mm. If you use a 5mm drill you'll make to hole too big. Then you start to wind it on over the screw.
You get to the end and - it's on!
Although you can see the break there is a good bit of metal inside there now. Gave the whole shelf a shampoo and spot clean while it was out too. Refitted the shelf and the fix seems pretty good.
 Cheers, Greg
Post #439815 27th May 2017 7:31pm
babagee
United Kingdom 2009 Range Rover Vogue TDV8 Stornoway Grey
Nice job - I've also a broken leg which has long been lost Sad 2009 Stornoway Grey Vogue TDV8
Post #439819 27th May 2017 8:24pm
GGDR
Yeah I was lucky to catch it as it snapped.
But once you have the screw in all you need is a bit of plastic the same diameter as the original (which yo can measure off the other side.
Then drill a hole through, screw it on and cut it to length.
. Cheers, Greg
Post #439820 27th May 2017 8:36pm
mjdronfield
I bought one from the dealer for minimum money a few years ago when one on my TD6 was iffy. Might be more money now...
Looks like a job well done.
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #439822 27th May 2017 8:58pm
Top fix
You do know you can buy them from Dan for a few squids Thumbs Up There is nothing that can't be fixed with a hammer😜😜
Post #439827 27th May 2017 9:55pm
GGDR
What the pegs? Can't beat the satisfaction of a quick, easy 5p fix to anything! Anyway I'd rather pretend I saved myself hundreds for a new shelf! Cheers!
. Cheers, Greg
Post #439844 28th May 2017 6:58am
GGDR
Also if you have one box of screws in your shed, the Screwfix 4x50 is the one to have. They're good for fixing all kinds.
. Cheers, Greg
Post #439849 28th May 2017 7:19am
Or 8g x 2" in old proper money..... Thumbs Up
I have more screws than I know what to do with, they tend to migrate home from site in my pockets and end up in the washing machine!
Yes the pegs (not the shelf) are available separately. Wink There is nothing that can't be fixed with a hammer😜😜
Post #439856 28th May 2017 7:56am
Zebedee
United Kingdom 2013 Range Rover Vogue SDV8 Santorini Black
The pegs are available individually from the dealer, so it is sometimes easier just to replace the part than to fix it. I replaced a peg with a new one a few months ago and I seem to remember they were only a couple of pounds each. Current:
- 2017 L405 3.0 V6 Autobiography
Sold:
- 2013 L405 4.4 TDV8 Vogue
- 2004 L322 4.4 Vogue (BRC LPG)
- 2002 L322 4.4 HSE (having fixed timing chain guides)
- 2000 P38 4.6 Vogue (BRC LPG)
- 1981 2-door In-Vogue
- 1980 Ex-Army SIII LWB
- 1976 SIII LWB
- 1968 SIIA
Stripped for parts:
- 2003 L322 4.4 Vogue
Post #439870 28th May 2017 9:53am
GGDR
I didn't realise you could get replacements cheap... But I've got that extremely satisfied feeling of fixing something for the cost of a 5p screw. Only took 10 mins too.
. Cheers, Greg
Post #439904 28th May 2017 9:13pm
Thumbs Up Thumbs Up Thumbs Up There is nothing that can't be fixed with a hammer😜😜
Post #439906 28th May 2017 9:28pm
nino_nino
love homemade solutions and satisfaction it brings. Thumbs Up
Post #439940 29th May 2017 9:31am
