![]() | Home > Maintenance & Mods (L322) > Reduced Engine Performance...again... |
SKOT Member Since: 24 Oct 2012 Location: Milton Keynes Posts: 792 ![]() ![]() ![]() |
Check the aux coolant pump is wired the correct way round (loads of posts online about the LR Technical Service Bulletin) - Many of them were wired incorrectly at build |
Bellini Member Since: 11 Jan 2012 Location: Berkshire Posts: 2261 ![]() ![]() ![]() |
As above. |
Knightmare Member Since: 22 Jun 2015 Location: Kent Posts: 84 ![]() ![]() ![]() |
Thanks guys, very helpful. |
unsolicited Member Since: 30 May 2016 Location: Bucks Posts: 128 ![]() ![]() ![]() |
Yup, supercharger pump vastly likely. If you have an IID tool you can confirm almost immediately. |
Thanks all, spot on...aux coolant pump was indeed wired incorrectly. |
Swapped pump for a new one. So far so good. Life is what happens while you�re making other plans. |
