Home > Maintenance & Mods (L322) > Reduced Engine Performance...again...
Knightmare
England 2007 Range Rover Supercharged 4.2 SC V8 Barolo Black
Morning all. Just wondered if anyone had any ideas about why I might be getting an intermittent ‘Reduced Engine Performance’ issue with the old girl. I’ve just had a pretty hefty 100k service, and in addition the guys applied various software updates. Most of the time we enjoy trouble free motoring. However, occasionally we get the fateful ‘bing’ and ‘Reduced Engine Performance’ kicks in and we’re desperately searching for somewhere to stop and switch off for a few minutes. Restarting seems to clear the ‘fault’.
The issue seems to occur if we’ve been, let’s say ‘driving enthusiastically’, but it’s not every time. I hate to say it but it seems to be getting more frequent. Any thoughts gratefully accepted.
Cheers Life is what happens while you�re making other plans.
Post #438410 15th May 2017 7:46am
SKOT
England 2006 Range Rover Supercharged 4.2 SC V8 Bonatti Grey
Check the aux coolant pump is wired the correct way round (loads of posts online about the LR Technical Service Bulletin) - Many of them were wired incorrectly at build Rolling Eyes
You may be lucky and the aux coolant pump doesn't mind spinning in the other direction! It's unlikely though, a new aux coolant pump is not hugely expensive and easy to fit. Thumbs Up 2006 4.2 SC
2019 Renault Zoe Dynamique Nav
Post #438411 15th May 2017 7:52am
As above. Thumbs Up
Happened to mine shortly after purchase and, fortunately, fixed under warranty. Si. <This is my name.
Post #438412 15th May 2017 8:09am
Knightmare
Thanks guys, very helpful. Thumbs Up
Will check it out and report back. Life is what happens while you�re making other plans.
Post #438421 15th May 2017 8:49am
unsolicited
United Kingdom 2017 Range Rover 5.0 SC V8 Mariana Black
Yup, supercharger pump vastly likely. If you have an IID tool you can confirm almost immediately.
Post #438500 15th May 2017 5:44pm
Knightmare
Thanks all, spot on...aux coolant pump was indeed wired incorrectly. Thumbs Up Life is what happens while you�re making other plans.
Post #438867 19th May 2017 8:29am
SKOT
Have you switched the wires only or switched the wires and replaced the coolant pump? 2006 4.2 SC
Post #438868 19th May 2017 8:31am
Knightmare
Swapped pump for a new one. So far so good. Life is what happens while you�re making other plans.
Post #438894 19th May 2017 3:01pm
