Home > General > A wee hello
scotcruz
Scotland 2010 Range Rover HSE TDV8 Zambezi Silver
A wee hello
Hi folks,
I am looking to get a 2010 RR this weekend and wanted the advice as to what I should be looking for.. So far the ones I have seen have the tailgate rust, the rear window seals rotten but other than that what should I be looking for mechanically and electronically.
Any help will be greatly appreciated
Many thanks
Post #437783 9th May 2017 9:57pm
scotcruz
123 views and no a single reply.. wow..
Post #438082 11th May 2017 9:20pm
StewD
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Java Black
There's a great WIKI on this site that has a buyers guide which points out what to look for.... that should be your starting point for a reference.
Your question has been asked many many times. The search facility is also very good and can be used over and over unlike some forums that have limited search capabilities....
Good luck in your quest. Current: Supercharged 06 FFRR in Java Black
Previous: BMW 740D M Sport
Previous Previous: BMW 730D Sport
Post #438087 11th May 2017 9:42pm
scotcruz
Thanks StewD.. appreciate your help..
Post #438088 11th May 2017 9:56pm
L_Ashman
United Kingdom 2007 Range Rover Vogue SE TDV8 Buckingham Blue
As Stew suggests, the Wiki is a great source of information.
Otherwise, I would recommend to look at as many as possible to get a 'feel' for the car as you can quite quickly notice one that has been well looked after / well serviced / nice and tight Laughing etc.
Also try to identify what options / extras are key for you... I had TV screens in mine but never used them! Hence they wouldn't fall into the 'must have' options for next time (I sold mine earlier this week, but will be back in another LR soon enough, I already miss it!).
Once you've got your wish list... it's then patience for the right car and willingness to travel.
Good luck in the search. Thumbs Up
Post #438147 12th May 2017 11:59am
GGDR
I got a lot of great advice here...
http://www.fullfatrr.com/forum/topic40852.html
and here:
http://www.fullfatrr.com/forum/topic40146.html
I got an RAC inspection. Pricey - and he didn't find a few things that I had to get the dealer to put right later under warranty. But even so it's worth thinking about.
If not then you can do it yourself, you will need 4-5 hours, checking every single function, test drive, climbing under. Follow the checklist on the wiki.
. Cheers, Greg
Post #438241 13th May 2017 8:58am
stu
A wee hello back to you and welcome to the gang. Thumbs Up Current: TDV8 (3.6) RRS HSE
Past: TDV8(4.4) Vogue
Discovery 3 Commercial
TDV8(3.6) Vogue
TD6 Vogue
D2 V8 ES
D1 V8 ES
RR Vogue Classic
Post #438258 13th May 2017 12:30pm
scotcruz
cheers folks
Post #438397 14th May 2017 7:48pm
