Home > Technical (L322) > Camshaft sensor problems maybe vanos solenoid what to buy
Willos
England 2002 Range Rover Vogue 4.4 V8 Java Black
Ive had no warning lights on the dash and the car drives fine. No misfire or stalling etc
Code reader says the following faults
Ive had camshaft sensor high bank 2 code P0348
Also p0021 timing over
Ladt week had vanos solenoid curcuit. I cleaned the contacts and checked resistance which was 10 ohms which is in the right area.
Ive cleared all codes but they come back
As i say no problems with the running or warning lights
Im going to change the camshaft sensor. Any recommendations on what to buy as there are loads on the market
I know i could swap over but im a firm believer in not fixing if its ok, so decided to change the one on bank 2 which i presume is on the uk passenger side bank
Post #436209 28th Apr 2017 9:44am
b348xyx
United Kingdom 2003 Range Rover Vogue 4.4 V8 Adriatic Blue
Camshaft Position Sensor is what i would replace first, Replace both sides if was me.
Then reset codes and see what comes back.
i used these http://www.ebay.co.uk/itm/232243506748?_tr...EBIDX%3AIT
couple weeks ago and are working fine. sure some will say go OEM but these are working fine for me.
P0021 can be caused by Sitcky Vanos solenoid, had this before aswell, these are little more expensive i would do above first. 2003 Range Rover 4.4 Litre V8 - Adriatic blue
2003 Range Rover 4.4 Litre V8 -Maintenance History Click Here = http://www.fullfatrr.com/forum/topic39687.html
Post #436215 28th Apr 2017 10:58am
Willos
Thanks for that Might consider buying 2 at that price
Post #436223 28th Apr 2017 11:30am
Willos
Just to follow up on my last post as some forget to conclude their thread when its been sorted.
I did buy the sensors as recommended by a helpful contributor of this forum. Now like most i was a little on the dubious side of cheap sensors, but i ordered 2 on friday afternoon and they arrived on the saturday post on a 24hr delivery.
On inspection they loooked well made. I replaced the side that was giving all the problems and cleared the codes.
Well alls fine. Car runs lovely with no more faults over 100 miles. It took no more than 15 mins to replace and only needed a 5mm allen key
I will do the other side today
Thanks for the help.
Like most faults around the vanos, dont think the worse, it could be cheap and simple
Post #436690 2nd May 2017 8:54am
b348xyx
Glad you got it sorted Smile 2003 Range Rover 4.4 Litre V8 - Adriatic blue
Post #436703 2nd May 2017 9:37am
